sevensegment_test.py Problem.
Re: sevensegment_test.py Problem.
by adafruit_support_carter on Mon Nov 30, 2020 12:57 pm
The video link did not come through for some reason.
The console output listing all looks fine. The final error output is indicating a connection issue. The lack of address in the i2c scan also indicates this.
Please try again to post the photos. Please layout all 4 of the displays next to each other, solder side up, and post a photo.
by goobertek on Wed Dec 02, 2020 3:38 pm
The system would only allow me to up load three images. Adding a post for the others.
goobertek
by goobertek on Wed Dec 02, 2020 3:39 pm
I really don't believe my soldering can be bad for all 5 of the backpacks. Do you have one soldered to your standard that you could send for testing?
goobertek
by adafruit_support_carter on Wed Dec 02, 2020 6:34 pm
The single photo with all four is adequate. Don't need a separate photo of each.
Sorry for confusing term - meant the header pin solder side. So opposite side as what's shown. Need to see the soldering here:
by goobertek on Wed Dec 02, 2020 10:04 pm
Here ya go. I appreciate the help. I hope this helps.
goobertek
by adafruit_support_carter on Thu Dec 03, 2020 2:05 pm
Thanks. Those look fine.
You've wired each of those up same as in your first photo?
and run the I2C scan and get nothing with any of them?
