Potentially defective 2.3" OLED - #2675
by shigeta on Wed Dec 23, 2020 3:07 pm
- Purchased Monochrome 2.3" 128x32 OLED Graphic Display Module Kit on December 5th, 2020 (Order 2429536-2427149833)
- Soldered header to OLED with no bridges or shorted connections, then wired to a RPi Zero exactly following the Adafruit documentation here for the SPI configuration: https://learn.adafruit.com/2-3-monochro ... lay-module
- Enabled the SPI communication in the Pi config text file
- When running the sample code from the Adafruit documentation, nothing happens. The code runs without errors, but the OLED remains completely blank. No indication of life.
- Verified that there is 3.3v across pins 1 & 2 of the OLED when the Pi is powered
Please advise on how to further troubleshoot or RMA this screen.
Cheers,
James
shigeta
Re: Potentially defective 2.3" OLED - #2675
by adafruit_support_carter on Mon Jan 04, 2021 2:11 pm
Can you please post another photo that also includes the Pi Zero so we can follow the wiring completely from the OLED to the Pi.
And just to be sure - is this the example code you are trying to run?
https://learn.adafruit.com/2-3-monochro ... 3046102-16
