- Purchased Monochrome 2.3" 128x32 OLED Graphic Display Module Kit on December 5th, 2020 (Order 2429536-2427149833)
- Soldered header to OLED with no bridges or shorted connections, then wired to a RPi Zero exactly following the Adafruit documentation here for the SPI configuration: https://learn.adafruit.com/2-3-monochro ... lay-module
- Enabled the SPI communication in the Pi config text file
- When running the sample code from the Adafruit documentation, nothing happens. The code runs without errors, but the OLED remains completely blank. No indication of life.
- Verified that there is 3.3v across pins 1 & 2 of the OLED when the Pi is powered
Please advise on how to further troubleshoot or RMA this screen.
Cheers,
James
