LED Board only using every 2 rows
by UnloosedCake on Wed Dec 30, 2020 9:30 pm
Purchased an LED Board and Pi bonnet and when I set them up only every two rows are being lit up - see photo. Any suggestions?
UnloosedCake
Re: LED Board only using every 2 rows
by UnloosedCake on Mon Jan 11, 2021 6:53 pm
Bump?
UnloosedCake
by adafruit_support_carter on Tue Jan 12, 2021 9:33 pm
Hey, sorry for missing this. Can you link to the specific LED panel you have as a start.
by UnloosedCake on Wed Jan 13, 2021 12:33 am
adafruit_support_carter wrote:Hey, sorry for missing this. Can you link to the specific LED panel you have as a start.
I'm using https://www.adafruit.com/product/2277
Along with https://www.adafruit.com/product/3211
UnloosedCake
by adafruit_support_carter on Wed Jan 13, 2021 12:26 pm
Thanks. That combo should be fine. So maybe something software related.
What model Pi are you using?
What OS image did you start with?
When you ran the installs script:
https://learn.adafruit.com/adafruit-rgb ... 1745233-16
Did you select the "quality" or "convenience" option?
by UnloosedCake on Wed Jan 13, 2021 3:02 pm
adafruit_support_carter wrote:Thanks. That combo should be fine. So maybe something software related.
I have a pi4 made by Canakit (8GB) https://www.canakit.com/raspberry-pi-4-starter-kit.html that I booted with the default raspbian OS. I chose convenience during the install because of the sound driver thing
UnloosedCake
by adafruit_support_carter on Wed Jan 13, 2021 3:28 pm
That should also all be OK.
What's the full command line you are using to run the example above?
