Just got this a couple of days ago and Tried hooking it up based upon the pictures on the Adafruit website. Hooking it up to a raspberry Pi B. When I first turned on the power there were multiple vertical lines on the screen. So much so that I could not see part of the home screen. Later On I powered it up and the only thing I see is what is captured in the photo below.
Tested that the HDMI cable works with a regular monitor and then I get the same set of vertical Lines when i connect it to a laptop running windows 10. Connections don't see loose. As it is supposed to be plug and play I have to assume its defective, unless there is something else I'm missing. Note the protective layer of plastic is still covering the screen, hence the barcode
