PiOLED not working
PiOLED not working
by dr_kiuchi on Mon Jan 04, 2021 5:51 pm
I'm running into the same exact issue as this thread: viewtopic.php?f=47&t=156198&p=788885&hilit=crashmoon#p788885
I've gone through all of the instructions step by step multiple times with the same results.
When I run stats.py nothing happens:
[pi@raspberrypi:~ $ sudo python3 ~pi/stats.py
^C
File "/home/pi/stats.py", line 136, in <module>
time.sleep(DISPLAY_OFF)
KeyboardInterrupt]
Pihole works fine, but can't get the OLED to work. Any assistance is appreciated.
Screen Shot 2020-12-29 at 11.02.38 AM.png (200.24 KiB) Viewed 35 times
dr_kiuchi
Re: PiOLED not working
by adafruit_support_carter on Mon Jan 04, 2021 6:11 pm
You're linking to a thread were someone had one of these:
https://www.adafruit.com/product/3973
with some apparent physical damage. Do you have the exact same PiOLED and issue? If so, can you please post a photo of the damage. If not, then just clarify the specific PiOLED product you are using.
