python3 adafruit_rgb_display library BORKed??
by destockwell on Tue Jan 05, 2021 4:40 pm
Starting about ten days ago, a python3 script started throwing Segmentation faults. After installing the faulthandler, I found that the following line was throwing the fault:
import adafruit_rgb_display.ili9341 as ili9341
A similar line causes the Segmentation fault:
import adafruit_rgb_display.st7789 as st7789
I tried reinstalling the adafruit_circuitpython_rgb_display library, even with --force-install, but the same Segmentation Fault is being thrown.
So, what else can I try? Or, is the library just borked?
Thanks for a quick reply...
destockwell
Re: python3 adafruit_rgb_display library BORKed??
by destockwell on Tue Jan 05, 2021 6:28 pm
command used for reinstall was:
sudo pip3 install --force-reinstall adafruit_circuitpython_rgb_display
destockwell
by destockwell on Wed Jan 06, 2021 12:37 pm
Looks like the fault is actually being thrown way down in numpy/numeric.py. Not sure why...
segfault.txt
Segmentation Fault Trace
(2.94 KiB) Downloaded 2 times
destockwell
by destockwell on Wed Jan 06, 2021 7:58 pm
Resolved the situation by pulling these test programs into an environment. Then installed local copies of numpy, plus adafruit_circuitpython_rgb_display, pillow, etc. into that environment.
Still getting used to the oddnesses of Python.
Anyway, looks like we are good to go.
destockwell
