Qualia bare driver issue
by Will_Griffith on Sun Jan 10, 2021 12:09 am
Has anyone run into this before? I can adjust it somewhat by changing resolution, but I can't get rid of the stacks and stacks of desktops.
Will_Griffith
Re: Qualia bare driver issue
by mikeysklar on Mon Jan 11, 2021 6:44 pm
That is strange almost like the Finder is getting confused.
What are you connecting into the Qualia bare board driver? eg. Macbook on one side of the DP? Are you using our 9.7" display for the other side? What version of OSX are you running?
mikeysklar
by Will_Griffith on Mon Jan 11, 2021 11:53 pm
Turned out to have been a bum cable. Swapped it out and it worked just fine. Now to figure out how to get it to work with my pi...
Will_Griffith
by mikeysklar on Tue Jan 12, 2021 3:26 pm
@Will_Griffith,
It can be done Pi --> DisplayPort.
/boot/config.txt setup:
https://www.raspberrypi.org/forums/view ... 0#p1202105
hdmi <--> displayport adapter:
https://www.cablematters.com/pc-825-139 ... black.aspx
mikeysklar
