8mm Neopixels running at 400khz
by Encinitas on Thu Mar 11, 2021 1:07 pm
I have been trying for a few days to get the 8mm diffused neopixels to work with the ft232h breakout. After trying many different OS/Driver/EEPROM configurations, and confirming that the ft232h was able to work with other SPI devices, I started to wonder if I had a timing issue. When i tried to run the neopixel at 800khz, it just shut off. When i set the code for 400khz, it works as intended. I mainly point this out in case anybody else runs into this problem, as all the provided datasheets say that the lights should run at 800khz.
import time
import board
import neopixel_spi as neopixel
NUM_PIXELS = 1
PIXEL_ORDER = neopixel.RGB
COLORS = (0xFF0000, 0x00FF00, 0x0000FF)
DELAY = 0.1
spi = board.SPI()
pixels = neopixel.NeoPixel_SPI(spi,
                               NUM_PIXELS,
                               pixel_order=PIXEL_ORDER,
                               frequency=3200000,
                               auto_write=False)
while True:
    for color in COLORS:
        for i in range(NUM_PIXELS):
            pixels[i] = color
            pixels.show()
            time.sleep(DELAY)
            pixels.fill(0)
Encinitas
