2345 no function
Re: 2345 no function
by adafruit_support_carter on Tue May 04, 2021 11:07 am
Go back and take a another look at the soldering. See here for a general reference:
https://learn.adafruit.com/adafruit-gui ... n-problems
These two pins looks good, so you can also use those a reference:
But check all the other pins. Maybe a solder bridge short here:
And any pins that look like this may not be wetted out enough on the pads:
by Autobotic95 on Thu May 06, 2021 5:20 am
Pins relocated and resoldered according to the tutorial provided.
All pins tested with multimeter, no short circuit, connectivity of the pads and pins are fine.
Run animation demo code, abnormal result.
Please refer to the videos
https://drive.google.com/file/d/1ScuS-T ... sp=sharing
https://drive.google.com/file/d/1CeabPX ... sp=sharing
https://drive.google.com/file/d/11irRHx ... sp=sharing
Autobotic95
by adafruit_support_carter on Thu May 06, 2021 12:00 pm
Thanks. That does look better. There is still a chance that something like a solder bridge may have done some permanent damage to the HAT by shorting pins. But let's just replace it and see if that helps. The second HAT works, so we at least know the rest of the hardware should be OK.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement RGB Matrix HAT (PID 2345).
