3.5" PiTFT HDMI Output Not Working
vedsvde
Post by vedsvde »
I've got a Raspberry Pi 4 8GB and have retried the installation process linked [/https://learn.adafruit.com/adafruit-pit ... -install-2]here[/url] over 4 times now. The screen will display the console with no problem but as soon as I switch it to HDMI mode, the screen goes completely black. The output on my HDMI monitor also becomes very garbled.
What can I do to fix it? The screen works since it displays the console with no problem. The HDMI output isn't working though :(
adafruit_support_carter
Re: 3.5" PiTFT HDMI Output Not Working
Can you clarify what you mean by "switch to HDMI mode". Are you re-running the install script and selecting the mirror HDMI option?
vedsvde
Post by vedsvde »
adafruit_support_carter wrote:Can you clarify what you mean by "switch to HDMI mode". Are you re-running the install script and selecting the mirror HDMI option?
Correct, that is what I'm doing.
Thanks. And then are you running the single command line option? Or via the interactive process (which is further down on page)?
vedsvde
Post by vedsvde »
https://imgur.com/a/DrdpNDd
This is what my monitor looks like. The actual PiTFT itself has a black screen.
vedsvde
Post by vedsvde »
adafruit_support_carter wrote:Thanks. And then are you running the single command line option? Or via the interactive process (which is further down on page)?
I am using the interactive process.
MakerMelissa
Post by MakerMelissa »
Hello, What happens if you don't have an HDMI cable plugged in and you boot?
o_spengler
Post by o_spengler »
I am having the same issue with mine.
GB_GH
Post by GB_GH »
Same problem here. Used...
> sudo python3 adafruit-pitft.py
to reconfig from console (worked fine) to mirror HDMI (blank PiTFT)
I don't have any HDMI devices.
GB.
o_spengler
Yep mine is still broke as well.
o_spengler
MakerMelissa wrote:Hello, What happens if you don't have an HDMI cable plugged in and you boot?
Ok, I finally got time to test this, when booting without HDMI plugged in the TFT screen is fine, to my great surprise.
Another note, the installer no longer works with older versions of Raspberry Pi OS, the so called "last known working" version from last December fails. Error is something along the lines of "unable to update apt indexes"
GB_GH
Post by GB_GH »
Hi o_spengler,
Which version of OS gave you the working TFT screen please ?
Is it safe to update to the latest version ?
Thanks, GB
o_spengler
GB_GH wrote:Hi o_spengler,
Thanks, GB
The latest version gave a working TFT with no HDMI plugged in.
Safe to upgrade? Eh... maybe?
GB_GH
Post by GB_GH »
Thanks for info.
G.
lbaute
Post by lbaute »
Mine is still broken, what was the solution for this?
Havin HDMI connector disconnected, doesn't sound like a final solution, I can connect and disconnect from inside the place I have it
