64x32 LED Matrix Lines
by RomaniDream on Thu Apr 01, 2021 12:00 am
This along with different patterns keep being displayed, and I have no idea why. Is this something I can fix? This is being powered with a 5-volt 4-amp power supply, a Raspberry Pi 3 A+, and a small RGB matrix bonnet.
Last edited by adafruit_support_carter on Thu Apr 01, 2021 11:13 am, edited 1 time in total.
Reason: move text from file comment to body
RomaniDream
Re: 64x32 LED Matrix Lines
by blnkjns on Thu Apr 01, 2021 6:49 am
It would be welcome to know what it should show. It helps to understand what goes wrong. For example wrong dimension or buffer setup.
blnkjns
by adafruit_support_carter on Thu Apr 01, 2021 11:14 am
Where did you get the LED matrix panel?
Is this the Bonnet you are using?
https://www.adafruit.com/product/3211
by RomaniDream on Thu Apr 01, 2021 7:06 pm
blnkjns wrote:It would be welcome to know what it should show. It helps to understand what goes wrong. For example wrong dimension or buffer setup.
Anything, really. The scanlines run properly, but it always shows these patterns when I try to display anything. The patterns only change when I power it on different times.
adafruit_support_carter wrote:Where did you get the LED matrix panel?
I got the panel from https://adafru.it/2278 and yes, that is the bonnet I'm using.
RomaniDream
by adafruit_support_carter on Thu Apr 01, 2021 7:19 pm
For the software setup, did you go through this process?
https://learn.adafruit.com/adafruit-rgb ... 1745233-16
If so, what is the command line for the example you are trying to run?
by RomaniDream on Thu Apr 01, 2021 7:32 pm
Yes, I followed the guide and ran that script. I tried c-example, clock, ledcat, and various demo programs from demo.
The command line for demo:
sudo ./demo --led-rows=32 --led-cols=64 --led-slowdown-gpio=4 -D 0 -t 10
And no matter what slowdown I use, it all looks the same.
RomaniDream
by adafruit_support_carter on Thu Apr 01, 2021 8:01 pm
Hmmm. OK, let's check the hardware further. Please post a photo showing the back of the panel and Pi so we can see how everything is connected together.
by RomaniDream on Thu Apr 01, 2021 8:16 pm
It's a basic setup for now, but here it is.
I do want to add that the first time I plugged this in, the bonnet didn't turn on until I reseated it. It might have something to do with this, but I'm not sure.
RomaniDream
by adafruit_support_carter on Thu Apr 01, 2021 8:34 pm
Thanks. That looks fine.
When you ran the install script, did you choose the "quality" or "convenience" option?
What operating system image are you starting with?
by RomaniDream on Thu Apr 01, 2021 8:39 pm
I chose the Convenience option. I'm using the regular Raspberry Pi OS distribution.
RomaniDream
by adafruit_support_carter on Fri Apr 02, 2021 1:10 pm
Weird. That all seems like pretty normal usage.
Can you post a photo of the backside of the Bonnet so we can look for any obvious hardware issues. A photo like this view:
https://cdn-shop.adafruit.com/970x728/3211-02.jpg
by RomaniDream on Fri Apr 02, 2021 9:42 pm
RomaniDream
by adafruit2 on Mon Apr 05, 2021 9:17 pm
yeah thats definitely odd output, lets try replacing the bonnet first
email support@adafruit with a link to this thread for a new bonnet.
adafruit2
Site Admin
by RomaniDream on Thu Apr 22, 2021 3:38 pm
I got the replacement bonnet, and here's what I did:
The first thing I did is connect it to the Raspberry Pi and plug in the power supply, and it started up normally. After that, I powered it off and connected the matrix panel, but then I got the exact same behavior: it didn't start when I connected power. This leads me to believe the matrix panel is actually at fault here.
RomaniDream
by adafruit2 on Thu Apr 22, 2021 5:08 pm
ok it was worth trying that first. you can email support for a new panel next
adafruit2
Site Admin
