Neotrellis interrupt wire
by Moris526 on Thu Apr 15, 2021 5:27 pm
Hi.
Im using Raspberry to contro Neotrellis led/Button board.
Im trying to read the interupt wire on the neotrellis board with this code:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
INPUT_PIN = 4
GPIO.setup(INPUT_PIN, GPIO.IN)
while True:
           if (GPIO.input(INPUT_PIN) == True):
                    print('1')
           else:
                    print('0')
But I get a stream of ones from the beginning, and nothing changes when I press a button.
Any idea? Not a programmer, as you can see.
Moris526
Re: Neotrellis interrupt wire
by dastels on Thu Apr 15, 2021 7:42 pm
Firstly, INT is active low (there's a pullup on the Neotrellis board) so you will want to watch for a low.
Style nitpick: comparing with True is redundant and probably wastes time and memory (though the byte compiler may optimize that away).
Finally, the interrupt feature has to be enabled. See keypad.py (~ line 76) https://github.com/adafruit/Adafruit_CircuitPython_seesaw/blob/9e06ac00fb27817b031b6b5acadd9542cab2989f/adafruit_seesaw/keypad.py#L76.
It looks like you're using plain cpython? You might consider using Blinka to give access to the CircuitPythion modules (notably adafruit_neotrellis). See https://learn.adafruit.com/circuitpython-on-raspberrypi-linux for more information.
dastels
by Moris526 on Sun Apr 25, 2021 11:28 am
Thanks for the answer.
I am using blinka
I can make it work with a button
Here is my current code
from board import SCL, SDA
import busio
from adafruit_neotrellis.noetrellis import NeoTrellis
from adafruit_neotrellis.multitrellis import MultiTrellis
INPUT_PIN = 21
GPIO.setup( INPUT_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP)
While (True):
      if (GPIO.input (INPUT_PIN)  == False):
              print ('1')
      else:
              print(´'0')
2 Questions:
1 - Does the interrupt indicates the board it comes from when theres is more than one?
2- Can you tell me how to enable the interrupt?
Moris526
by Moris526 on Thu May 06, 2021 7:00 pm
Please ??
Moris526
by Moris526 on Sat May 15, 2021 8:28 pm
Pretty pleasseee
Moris526
