32x64 LED Matrix - one section blinks incorrectly
by Nancy4c on Tue Apr 20, 2021 9:16 pm
I'm attempting to run the "Creature Eyes" project on my new 32x64 5mm LED matrix using the Matrix Portal M4. 75% of the screen is working properly but one corner is flickering and displaying incorrect colors. I've tried multiple .bmp "eye" types and the same corner keeps malfunctioning. Any advice? The "bad" section is approximately 16x46 on the top left side.
Nancy4c
Re: 32x64 LED Matrix - one section blinks incorrectly
by dastels on Tue Apr 20, 2021 10:31 pm
Can you try other demos to see if the problem is independent of code.
dastels
by Nancy4c on Tue Apr 20, 2021 11:07 pm
Thanks for the response. I'll give that a try tomorrow. :)
Nancy4c
by Nancy4c on Thu Apr 22, 2021 4:47 pm
I ran another demo and the same corner of the matrix is acting funky. That area displays the wrong color and flickers.
Matrix Trouble.jpeg (640.76 KiB) Viewed 141 times
Nancy4c
by Nancy4c on Tue May 04, 2021 6:41 pm
Still looking for help with this. Any ideas? Thanks!
Nancy4c
by adafruit2 on Fri May 07, 2021 12:40 pm
just whats your power supply? if its either too high or too low that could cause some issue. if not we can replace the matrix!
adafruit2
Site Admin
by Nancy4c on Sat May 08, 2021 10:44 pm
Hi!
When I took the pictures, it was plugged into my laptop. I got similar results when I plugged it into the outlet I use to power my iPhone.
Nancy4c
