QT PY RP2040 and 1.3" 128x64 OLED Pullup
by zelthian on Thu Apr 22, 2021 8:36 pm
I'm having an issue with my QT PY RP2040 and 1.3" OLED. I have them connected via the STEMMA QT connector and loaded the OLED CircuitPython example code from the Learn site. I'm getting this error:
"RuntimeError: No pull up found on SDA or SCL; check your wiring"
The OLED has pull-up resistors built in, according to the schematic. What am I doing wrong?
zelthian
Re: QT PY RP2040 and 1.3" 128x64 OLED Pullup
by zelthian on Thu Apr 22, 2021 10:45 pm
Got it working. I found this other post:
viewtopic.php?f=52&t=178181
From this, I worked out that if I added the busio library:
import busio
and changed:
i2c = board.I2C()
to:
i2c = busio.I2C(board.SCL1, board.SDA1)
the display example code now works.
zelthian
by devellison on Wed May 12, 2021 11:20 am
Thanks for this. That worked for me, had the exact same issue.
devellison
by adafruit_support_carter on Wed May 12, 2021 12:55 pm
Correct. Those are the STEMMA QT pins:
https://learn.adafruit.com/adafruit-qt- ... -3091651-3
by zelthian on Sat May 15, 2021 2:14 am
adafruit_support_carter wrote:Correct. Those are the STEMMA QT pins:
Yeah, I missed that info. Loaded up Circuit Python and went right for the OLED example code.
zelthian
