adafruit 32x32 rgb matrix error
by KAMSng on Mon Apr 26, 2021 5:14 am
I made up a circuit with arduino mega,5v 3a smps, and adafruit 32x32 rgb matrix. then put a example code but It doesn’t print correctly. I checked connections several times and I attempted to change the version of liabrary but it doesn’t work. It must be print "adafruit 32x32 rgb" but it print akward character. It looks similar to correct character but it does not come out exactly.
https://aws1.discourse-cdn.com/github/o ... a9de3.jpeg
HOW CAN I FIX IT?
ada fruit 32x32 rgb print.jpg (28.75 KiB) Viewed 93 times
KAMSng
Re: adafruit 32x32 rgb matrix error
by adafruit_support_carter on Mon Apr 26, 2021 12:10 pm
How are you connecting the RGB matrix to the Mega?
by KAMSng on Mon Apr 26, 2021 8:59 pm
adafruit_support_carter wrote:How are you connecting the RGB matrix to the Mega?
I made it out of this.
KAMSng
by adafruit_support_carter on Tue Apr 27, 2021 10:52 am
Are you using jumper wires? If so, that approach very often does not work do to the general complexity of the setup and high likely hood for incorrect or bad wiring:
https://learn.adafruit.com/32x16-32x32- ... mper-wires
We recommend using a shield:
https://www.adafruit.com/product/2601
by KAMSng on Wed Apr 28, 2021 8:41 pm
adafruit_support_carter wrote:Are you using jumper wires? If so, that approach very often does not work do to the general complexity of the setup and high likely hood for incorrect or bad wiring:
I considered shield but It's availabe on arduino UNO, Can I use it on arduino mega 2560?
The manual said mega need additional wiring but I can't find detail explanation.
KAMSng
