Neopixel Strip dimension
by kennykim on Sun May 02, 2021 2:06 am
I'm trying to design USB-C adapter for NeoPixel Digital RGB LED Strip(1461) and Mini Skinny(2964), but there is some unspecified dimensions of them.
I want to connect them without wire(using solder beads), so What is the pitch of each pads and its width?
Kenny.
kennykim
Re: Neopixel Strip dimension
by blnkjns on Sun May 02, 2021 5:16 am
It's in the specs:
1461:
12.5mm (0.5") wide, 4mm (0.16") thick with casing on, 16.7mm (0.65") long per segment
60 LEDs per meter
2964
7.5mm (0.3") wide, 4mm (0.16") thick with casing on, 16mm (0.63") long per segment
60 LEDs per meter
Solderpads seem to be regular 0.254mm spaced. I measured with photopea.com from this image:
Mr. curly hair is on 24.26 mm of metal
blnkjns
by carlboost on Sat May 08, 2021 5:29 pm
blnkjns wrote:It's in the specs:
1461:
60 LEDs per meter
2964
60 LEDs per meter
carlboost
