RGB LED Matrix & HAT - Impromptu Restart
by mozart27 on Sun May 02, 2021 2:37 pm
I'm trying to run the demos on my RGB LED 64x64 matrix (PID: 3649) with the Adafruit RGB Matrix HAT + RTC for Raspberry Pi - Mini Kit (PID: 2345).
I've soldered the pad to accommodate the 64x64 matrix with this HAT.
I've downloaded and installed the demo app using these steps:
curl https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/rgb-matrix.sh >rgb-matrix.sh
sudo bash rgb-matrix.sh
Whenever I run the demo
sudo ./demo -D0 --led-rows=32 --led-cols=1
the pi displays the following text and restarts.
Any thoughts on what I might be doing wrong?
Thanks in advance - jb
mozart27
Re: RGB LED Matrix & HAT - Impromptu Restart
by dastels on Sun May 02, 2021 4:07 pm
You didn't post the output.
What's happening on the matrix when it restarts?
How are you powering everything?
dastels
by mozart27 on Sun May 02, 2021 5:13 pm
For power, I have the normal 5V microUSB plugged into the pi3 and another 5V 3A plugged into the HAT.
The output from the command is:
pi@raspberrypi:~/src/rpi-rgb-led-matrix/examples-api-use $ sudo ./demo -D0 --led-rows=32 --led-cols=16
Size: 16x32. Hardware gpio mapping: adafruit-hat
Press <CTRL-C> to exit and reset LEDs
Connection to 192.168.1.64 closed by remote host.
Connection to 192.168.1.64 closed.
mozart27
by dastels on Sun May 02, 2021 7:30 pm
Huh. So no information about what causes the restart.
dastels
by mozart27 on Sun May 02, 2021 8:53 pm
Yeah exactly. Nothing I can detect. Could under-voltage cause a spontaneous restart?
mozart27
