Um having trouble getting the laser range finder module and the TFT to work together... seems like they use the same timer if I output the laser to the serial monitor it works fine.. if I separately use the TFT it works too... but when I put them together the display flashes white. And the laser reads 0 or nothing at all...
I also tried the arduino TFT library with the same result.
Which timers are used in the tft? And which in the laser module ???
Then I can hunt for a driver library that will not conflict.
Thanks for all assistance
TFT 7735 with LOX50 laser module
- blnkjns
Re: TFT 7735 with LOX50 laser module
We need some info:
What board do you use?
How are things wired?
What code do you try to run?
- MollyJanet
issue got solveddMollyJanet wrote:Um having trouble getting the laser range finder module and the TFT to work together... seems like they use the same timer if I output the laser to the serial monitor it works fine.. if I separately use the TFT it works too... but when I put them together the display flashes white. And the laser reads 0 or nothing at all...
I also tried the arduino TFT library with the same result.https://nox.tips/ https://BANNED.vip/
