TFT 7735 with LOX50 laser module
by MollyJanet on Tue May 04, 2021 9:15 am
Um having trouble getting the laser range finder module and the TFT to work together... seems like they use the same timer if I output the laser to the serial monitor it works fine.. if I separately use the TFT it works too... but when I put them together the display flashes white. And the laser reads 0 or nothing at all...
I also tried the arduino TFT library with the same result.
Which timers are used in the tft? And which in the laser module ???
Then I can hunt for a driver library that will not conflict.
Thanks for all assistance
MollyJanet
Re: TFT 7735 with LOX50 laser module
by blnkjns on Tue May 04, 2021 9:47 am
We need some info:
What board do you use?
How are things wired?
What code do you try to run?
blnkjns
by MollyJanet on Wed May 05, 2021 5:13 am
MollyJanet wrote:Um having trouble getting the laser range finder module and the TFT to work together... seems like they use the same timer if I output the laser to the serial monitor it works fine.. if I separately use the TFT it works too... but when I put them together the display flashes white. And the laser reads 0 or nothing at all...
I also tried the arduino TFT library with the same result.https://nox.tips/ https://xender.vip/
issue got solvedd
MollyJanet
