PITFT 2.2 Does not work!
by doomer170 on Fri May 07, 2021 12:29 am
I'm making a gameboy zero, I followed the instructions on your site very closely, the screen lights up but nothing shows up on screen. My soldering joints are just about perfect as well. I am certain I recieved a defective screen.
doomer170
Re: PITFT 2.2 Does not work!
by adafruit_support_carter on Fri May 07, 2021 3:36 pm
Which specific guide are you following?
Can you post a photo of your build showing the soldering connections between the Pi Zero and TFT.
by doomer170 on Sat May 08, 2021 4:16 am
adafruit (1).jpg (219.45 KiB) Viewed 91 times
This is the tutorial I followed:
https://learn.adafruit.com/running-open ... itft-setup
doomer170
by adafruit_support_carter on Mon May 10, 2021 10:58 am
Thanks for the photo. Can't tell for sure if all pins are good from that angle. But let's try some software things first. What OS image were you starting with?
by doomer170 on Tue May 11, 2021 3:24 am
I used the latest version of Retro pie from https://retropie.org.uk/download/
I of course chose the download for Raspberry Pi Zero. From there I followed the instructions at:
After failing to get any display on the PiTFT 2.2 I formatted my SD card and Flashed retropie again with Balena Etcher and started over, following the instructions VERY closely, and I have repeated all of that about 5 times now before finally consulting you guys here on adafruit.
doomer170
by adafruit_support_carter on Tue May 11, 2021 10:23 am
Are you at least getting the back light on the TFT to come on?
Can you post another photo more at 45def angle of the soldering.
by doomer170 on Thu May 13, 2021 4:55 am
Yes the back light was coming on all along, I've got GOOD NEWS, it was the ribbon cable on the back of the screen, I ran my soldering iron across it to reflow the solder and the screen works now! Thank god! I appreciate your time and effort trying to help me out.
doomer170
by adafruit_support_carter on Thu May 13, 2021 11:16 am
Cool. Nice work. Happy to help and glad it's working now. Thanks for letting us know. Have fun!
