64x32 Flexible RGB LED Matrix - 5mm with Matrix Portal flick
by bonMiece on Sat May 08, 2021 1:12 pm
Finally got around to testing out an LED matrix with Matrix Portal, but I'm having an issue where the top left quarter (approximately, it is slightly more area than that) is flickering and displaying the wrong colors. I've tried a few different projects, get the same static across all tests. Power is being supplied by the Matrix Portal. I'm a software person not a hardware person, so not really sure what to try to fix this.
bonMiece
Re: 64x32 Flexible RGB LED Matrix - 5mm with Matrix Portal f
by adafruit2 on Mon May 10, 2021 12:20 pm
try installing the simpletest UF2 here
https://learn.adafruit.com/adafruit-mat ... /downloads
what does it look like with that on?
adafruit2
Site Admin
by bonMiece on Mon May 10, 2021 12:37 pm
My guess is it isn't supposed to look like this
bonMiece
by bonMiece on Fri May 21, 2021 2:54 pm
Any more help on this?
bonMiece
by adafruit2 on Mon Jun 14, 2021 12:18 pm
hi just to check, how are you powering the matrixportal + matrix?
adafruit2
Site Admin
by bonMiece on Sun Jun 20, 2021 11:10 am
Via the USB from the computer.
bonMiece
