SD problem using Adafruit 2.8" TFT Touch Shield v2
by Bazza on Wed May 26, 2021 3:27 pm
Hi, I am using the resistive version of the shield and a Uno. I have an issue with what appears to be a conflict when I add the the code to include SD routines. I'm using hardware SPI and the code uploads without a problem but the screen is blank and the touch doesn't work. I use 8 as the SD chip select. Any suggestions appreciated.
Bazza
Re: SD problem using Adafruit 2.8" TFT Touch Shield v2
by mikeysklar on Wed May 26, 2021 8:00 pm
Bazza,
Since the TFT and SD card sharing the SPI bus you will need to manually toggle the CS pins when flipping between the two devices. Pulling the CS pin high on the TFT and the SD CS pin low will give the SD card control of the bus. Doing the reverse will give the TFT control of the SPI bus.
mikeysklar
by Bazza on Tue Jun 01, 2021 7:41 am
Thanks for the prompt reply. I actually solved this by accident. I was looking at one of the Adafruit examples for loading bmp images from SD and realized that you have to insert the SD card before it can be enabled. Everything works fine now
Bazza
