ST7735 Color Display
by Leobute on Sun May 30, 2021 4:05 pm
HI.
I use and it works for me the Color display using the Adafruit_ST7735 library.
My only question is :
How can i do a check to see if the display is connected ?
There is not a begin nor other function that return true or false in case the display cannot be initialized.
Any Help ?
Thanks a lot.
Leobute
Re: ST7735 Color Display
by adafruit_support_mike on Sun May 30, 2021 7:34 pm
Leobute wrote:How can i do a check to see if the display is connected ?
Our libraries assume the display is connected and ready to talk.
I suppose you could try sending an SPI message to the display and see if there's any response.
by Leobute on Mon May 31, 2021 5:04 am
Hi, thanks for the reply.
Using your adafruit library for another kind of display, ex : SSD1306, i found the begin(xxx) returing a true or false.
So i was expecting the same for the ST7735.
Can you help me in providing me an SPI command for the ST7735 just to see if i can manage the check i need ?
Really thanks
Leonardo
Leobute
