Adafruit_TouchScreen not working with ESP32
by Ckyiu on Tue Jun 01, 2021 9:56 pm
So I bought this 2.8in TFT (https://www.adafruit.com/product/1770) at Microcenter the other day and was having lots of fun with it and a generic ESP32 dev kit module. The display part worked great with my ESP32! But once I got to the touch screen part it stopped working. I wired up the touch connections to the ESP32 and touching did nothing! So I grabbed an Arduino Uno and the display and touch worked perfectly fine so the touch overlay wasn't faulty. I composed the following sketch to test the touch screen:
#if defined(ESP32)
// These are the four touchscreen analog pins
#define YP A3  // must be an analog pin, use "An" notation!
#define XP 22  // can be any digital pin
#define YM 21  // can be any digital pin
#define XM A0  // must be an analog pin, use "An" notation!
#else  // Arduino Uno in my case
#define YP A0  // must be an analog pin, use "An" notation!
#define XP A1   // can be any digital pin
#define YM A2   // can be any digital pin
#define XM A3  // must be an analog pin, use "An" notation!
#endif
  // put your setup code here, to run once:
  Serial.begin(9600);
#if defined(ESP32)
  analogReadResolution(10);
#endif
  // put your main code here, to run repeatedly:
  pinMode(XP, OUTPUT);
  pinMode(YP, INPUT);
  digitalWrite(XP, HIGH);
  Serial.print("X+ --> Y+: ");
  Serial.print(analogRead(YP));
  digitalWrite(XP, LOW);
  pinMode(YM, OUTPUT);
  pinMode(XM, INPUT);
  digitalWrite(YM, HIGH);
  Serial.print("     Y- --> X-: ");
  Serial.println(analogRead(XM));
  digitalWrite(YM, LOW);
  delay(20);
Which resulted in similar results on both chips:
No touching:
21:45:26.294 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:26.341 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:26.388 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:26.435 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:26.483 -> X+ --> Y+: 0     Y- --> X-: 0
Started at one corner and started "dragging" to the opposite corner:
21:45:26.530 -> X+ --> Y+: 39     Y- --> X-: 228
21:45:26.530 -> X+ --> Y+: 40     Y- --> X-: 240
21:45:26.577 -> X+ --> Y+: 44     Y- --> X-: 236
21:45:26.624 -> X+ --> Y+: 42     Y- --> X-: 224
21:45:26.671 -> X+ --> Y+: 57     Y- --> X-: 227
21:45:26.671 -> X+ --> Y+: 76     Y- --> X-: 222
21:45:26.718 -> X+ --> Y+: 95     Y- --> X-: 217
21:45:26.764 -> X+ --> Y+: 124     Y- --> X-: 202
21:45:26.810 -> X+ --> Y+: 155     Y- --> X-: 185
21:45:26.810 -> X+ --> Y+: 173     Y- --> X-: 177
21:45:26.857 -> X+ --> Y+: 204     Y- --> X-: 157
21:45:26.905 -> X+ --> Y+: 232     Y- --> X-: 140
21:45:26.950 -> X+ --> Y+: 246     Y- --> X-: 122
21:45:26.997 -> X+ --> Y+: 263     Y- --> X-: 109
21:45:26.997 -> X+ --> Y+: 284     Y- --> X-: 96
21:45:27.044 -> X+ --> Y+: 304     Y- --> X-: 84
21:45:27.089 -> X+ --> Y+: 303     Y- --> X-: 76
Released:
21:45:27.137 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:27.183 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:27.230 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:27.276 -> X+ --> Y+: 0     Y- --> X-: 0
21:45:27.323 -> X+ --> Y+: 0     Y- --> X-: 0
But when I use the Adafruit_Touchscreen library (https://github.com/adafruit/Adafruit_TouchScreen) the results get all wonky as such:
  This is our touchscreen painting example for the Adafruit ILI9341 Breakout
  ----> http://www.adafruit.com/products/1770
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
/** NOT FOR USE WITH THE TOUCH SHIELD, ONLY FOR THE BREAKOUT! **/
#include <Adafruit_GFX.h>    // Core graphics library
#include <SPI.h>
#include <Adafruit_ILI9341.h>
#include "TouchScreen.h"
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// The display uses hardware SPI, plus #9 & #10
#define TFT_CS 5
#define TFT_DC 17
#define TFT_MOSI 23
#define TFT_CLK 18
#define TFT_RST -1
#define TFT_MISO 19
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 125);
// Size of the color selection boxes and the paintbrush size
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
 // while (!Serial);     // used for leonardo debugging
  Serial.begin(9600);
  Serial.println(F("Touch Paint!"));
  tft.begin();
  tft.fillScreen(ILI9341_BLACK);
  // make the color selection boxes
  tft.fillRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_RED);
  tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_YELLOW);
  tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_GREEN);
  tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_CYAN);
  tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_BLUE);
  tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_MAGENTA);
  // select the current color 'red'
  tft.drawRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
  currentcolor = ILI9341_RED;
void loop()
  // Retrieve a point
  TSPoint p = ts.getPoint();
  Serial.print("X: "); Serial.print(p.x);
  Serial.print("\tY: "); Serial.print(p.y);
  Serial.print("\tP: "); Serial.println(p.z);
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z < MINPRESSURE || p.z > MAXPRESSURE) {
     return;
  // Scale from ~0->1000 to tft.width using the calibration #'s
  p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
  p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
//  Serial.print("("); Serial.print(p.x);
//  Serial.print(", "); Serial.print(p.y);
//  Serial.println(")");
  if (p.y < BOXSIZE) {
     oldcolor = currentcolor;
     if (p.x < BOXSIZE) {
     } else if (p.x < BOXSIZE*2) {
       currentcolor = ILI9341_YELLOW;
       tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*3) {
       currentcolor = ILI9341_GREEN;
       tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*4) {
       currentcolor = ILI9341_CYAN;
       tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*5) {
       currentcolor = ILI9341_BLUE;
       tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*6) {
       currentcolor = ILI9341_MAGENTA;
       tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     if (oldcolor != currentcolor) {
        if (oldcolor == ILI9341_RED)
        if (oldcolor == ILI9341_YELLOW)
        if (oldcolor == ILI9341_GREEN)
        if (oldcolor == ILI9341_CYAN)
        if (oldcolor == ILI9341_BLUE)
        if (oldcolor == ILI9341_MAGENTA)
  if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
    tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
No touching:
21:43:00.494 -> X: 0   Y: 817   P: 0
21:43:00.494 -> X: 0   Y: 611   P: 0
21:43:00.494 -> X: 0   Y: 803   P: 0
21:43:00.540 -> X: 0   Y: 851   P: 0
21:43:00.540 -> X: 0   Y: 828   P: -1
21:43:00.586 -> X: 0   Y: 600   P: 0
21:43:00.586 -> X: 507   Y: 584   P: 0
21:43:00.586 -> X: 494   Y: 637   P: 0
21:43:00.634 -> X: 490   Y: 787   P: 0
21:43:00.634 -> X: 0   Y: 842   P: 0
21:43:00.681 -> X: 448   Y: 842   P: 0
21:43:00.681 -> X: 0   Y: 855   P: 0
Started touching:
21:43:00.730 -> X: 0   Y: 1023   P: 0
21:43:00.776 -> X: 0   Y: 1023   P: 0
21:43:00.824 -> X: 0   Y: 1023   P: 0
21:43:00.870 -> X: 0   Y: 1023   P: 0
21:43:00.918 -> X: 0   Y: 1023   P: 0
Released:
21:43:00.918 -> X: 495   Y: 697   P: 0
21:43:00.963 -> X: 312   Y: 847   P: 0
21:43:00.963 -> X: 0   Y: 859   P: 0
21:43:00.963 -> X: 283   Y: 587   P: 0
21:43:01.010 -> X: 499   Y: 605   P: 0
21:43:01.010 -> X: 488   Y: 795   P: 0
21:43:01.056 -> X: 0   Y: 835   P: 0
21:43:01.056 -> X: 475   Y: 802   P: 0
21:43:01.103 -> X: 0   Y: 831   P: -1
21:43:01.103 -> X: 436   Y: 608   P: 0
21:43:01.149 -> X: 480   Y: 611   P: 0
21:43:01.149 -> X: 0   Y: 611   P: 0
Is the Adafruit Touchscreen library not suited for the ESP32? Are there any modifications I can make to the library? I am able to locate and edit the library code on my machine if the need arises.
Ckyiu
Re: Adafruit_TouchScreen not working with ESP32
by blnkjns on Fri Jun 04, 2021 12:32 am
Do you have the 2 analog inputs on real analog pins on the ESP?
Sometimes the define-ifs don't work correctly. You can try to force the code for the ESP by removing all clutter around it:
#if defined(ESP32)
#endif
  Serial.begin(9600);
#if defined(ESP32)
#endif
Becomes:
  Serial.begin(9600);
blnkjns
by Ckyiu on Fri Jun 04, 2021 7:45 am
I believe they are on "real" analog pins. The result is still the same even if did what you suggested. (removing the #if defined(ESP32))
I've also tried writing my own code to get the touch points, and it's hard to get it remotely accurate with what I'm doing.
Ckyiu
by Ckyiu on Sat Jun 05, 2021 2:39 pm
So I was gonna try using CircuitPython and a Feather M0 basic with the touchscreen and I noticed this code example in the library readme: (https://github.com/adafruit/Adafruit_Ci ... ge-example)
import board
import adafruit_touchscreen
# These pins are used as both analog and digital!
# XR, XL and YU must be analog and digital capable.
# YD just needs to be digital.
ts = adafruit_touchscreen.Touchscreen(board.TOUCH_XL, board.TOUCH_XR,
                      board.TOUCH_YD, board.TOUCH_YU)
while True:
    p = ts.touch_point
    if p:
    print(p)
So is this a typo or this is true? That 3 of the pins need to be analog and digital?
Ckyiu
by Ckyiu on Sun Jun 06, 2021 2:42 pm
Looking through this "guide" I found:
https://www.thesmarthomehookup.com/node ... d-outputs/
There are many pins on the ESP32 which have restrictions on them. So just keep switching around pins cause lots of them can't have pull ups/downs or can't be input/output. After changing the pins and changing the ADC resolution (via https://github.com/adafruit/Adafruit_To ... /issues/15) it worked!
Ckyiu
by blnkjns on Mon Jun 07, 2021 12:32 am
So which pins to use?
blnkjns
by Ckyiu on Mon Jun 07, 2021 11:13 am
These pins worked for me:
const byte YP = A4;
const byte XP = A5;
const byte YM = A18;
const byte XM = A19;
Ckyiu
