I'd like to control 12 Dotstar strips independantly: like a matrix of Dostars.
The purpose is to use them to display image and the best would be animated images.
The Processing¨project could be perfect for this but FadeCandy doesn't manage SPI.
So my question is divided as 2 parts :
- The Raspberry can't be used as there is only 2 SPI on it = which board could provide 12 SPI ports ?
- I've been taking a long time to search for already made libraries (see below) but they don't allow to "project" image or animation = how to have an image or animation.
This could be from something to adapt or eventually to program as a python code.
From all I've been searching :
- https://learn.adafruit.com/circuitpytho ... el-mapping
- https://learn.adafruit.com/circuitpytho ... -libraries
- https://www.digikey.com/en/maker/projec ... 35f0166958
how to use different Dotstar strips ?
- adafruit_support_carter
Re: how to use different Dotstar strips ?
Do the 12 strips comprise a single matrix? If so, it's best to just chain them as a single strip and then do math to deal with addressing things as a matrix. That's what the PixelMap helper does. That is part of the Animation library, but the general approach would be the same.
- mouha
Thank you for your answer.
Actually, all of these strips are this matrix right.
However, the Pixelmap helper seems only to display some kind of animations like :
- rainbow_v,
- comet_h,
- rainbow_comet_v,
- chase_h,
- rainbow_chase_v,
- comet_v,
- rainbow_chase,
Yep, it doesn't have exactly what you want. But it's the same general idea, in terms of using a single SPI port vs. one for each row.
- mouha
I see.
I'd like to know however how it's possible to connect many SPI slaves from a board like PI, Oodo,BeagleBone, etc
All my searches in Adafruit didn't gave any result: like SPI exander nor multiplexer, etc
You can have more than one device on a SPI bus. They share SCLK/MOSI/MISO pins. Each one needs a dedicated chip select (CS) pin, which is just any available GPIO pin.
DotStar is not truly a SPI device. It's communication protocol is SPI-like, and it can be driven with a SPI bus. But it doesn't have a CS pin, so won't play nice with other devices on a SPI bus.
- mouha
Oh no ... I've bought 12 of them already .
So it means I can't control them via FadeCandy nor as SPI slaves ?
Controlling them through Processing neither (like with the FadeCandy) ?
Fadecandy is for use with NeoPixels, which are a little different than DotStars. NeoPixels do not have a dedicated clock line.
There's a brief DotStar vs. NeoPixel comparison here:
https://learn.adafruit.com/adafruit-dot ... s/overview
- mouha
thanks.
In conclusion : no hope to use 12 dotstars strips as a matrix to display my personal images as animation ?
It's totally possible. Same general suggestion as above - have a single strip and do the matrix-ification in software. Similar to this Arduino library:
https://github.com/adafruit/Adafruit_DotStarMatrix
Then just need something that would go from image/animation to actual DotStar data buffer.
- mouha
thanks adafruit_support_carter.
I
I
