Fade Candy led imitation workaround
by mouha on Sat Jun 19, 2021 7:24 pm
I'd like to use the Fade Candy with processing to display animations in a matrix ( 10 columns made of strips ) made of Adafruit neomatrix strips.
But before buying Adafruit Strips I was wondering if it were possible to workaround the 64 leds limitation of the FC by adding 2 strips (let's sat 2x60 leds) to make a single column of this matrix which then would require 2 outputs.
Does this implies to define a new PDE to be able to control each column made of 2 strips from 2 FC outputs ? or is there a better solution ?
mouha
