1.44 TFT display integration with audrino maker 1500
by dkanday on Tue Jun 22, 2021 5:13 pm
I am trying to integrate the audrino maker 1500NB with 1.44TFT display but it seems to be that the example code: graphictest doesnt work with it. I used the same display with audrino uno and it worked fine. I followed all the wiring from this link: https://learn.adafruit.com/adafruit-1-4 ... g-and-test
I modified the code to use pin 7 on the maker to act as the CS pin but that did not help.
Is there something that I could have missed?
Thanks in advance for the help!
dkanday
Re: 1.44 TFT display integration with audrino maker 1500
by blnkjns on Thu Jun 24, 2021 5:23 am
You use the hardware SPI pins? Pin 8,9,10.
blnkjns
by dkanday on Thu Jun 24, 2021 6:06 pm
Yes I tried using them but the display did not do anything other than turning on and a white screen
dkanday
by dkanday on Fri Jun 25, 2021 2:46 pm
sorry I was initializing the pins incorrectly in code. Fixed that and it worked.
dkanday
