Faulty E-Ink Display?
by jpBane on Wed Jun 23, 2021 6:40 am
Dear customer support team,
I recently purchased an adafruit 2.13" Monochrome E-Ink Bonnet for Raspberry Pi via thepihut.com.
To perform a first test, I used the https://learn.adafruit.com/raspberry-pi-e-ink-weather-station-using-python project.
Unfortunately, it seems that the display does not work properly since a couple of lines just show random noise and a part of the output is cut off. If I rotate the output by 180 degrees adjusting the "display.rotation" command in the python script, the random noise is still at the same spot.
Is this because of a faulty display or am I doing anything wrong?
Any help is highly appreciated.
Kind regards,
jpBane
jpBane
