Whenever I display to the first screen on CE0, it's fine (i.e. only displays on the first screen), but displaying to the second screen (CE1) pushes the same image to both screens. I can't seem to figure out why. Trying to manually throw CE0 high hasn't appeared to work.
Here's the implementation (adjusted from the sample code for python usage seen here: https://learn.adafruit.com/2-2-tft-display):
import digitalio
import board
from PIL import Image, ImageDraw, ImageFont
import adafruit_rgb_display.ili9341 as ili9341
import time
# First define some constants to allow easy resizing of shapes.
BORDER = 0
FONTSIZE = 24
# Configuration for CS and DC pins (these are PiTFT defaults):
cs_pin = digitalio.DigitalInOut(board.CE0)
cs2_pin = digitalio.DigitalInOut(board.CE1)
dc_pin = digitalio.DigitalInOut(board.D25)
dc2_pin = digitalio.DigitalInOut(board.D25)
reset_pin = digitalio.DigitalInOut(board.D24)
reset_pin2 = digitalio.DigitalInOut(board.D24)
# Config for display baudrate (default max is 24mhz):
BAUDRATE = 24000000
# Setup SPI bus using hardware SPI:
spi = board.SPI()
print('spi set up')
# pylint: disable=line-too-long
# Create the display:
disp = ili9341.ILI9341(
spi,
rotation=90, # 2.2", 2.4", 2.8", 3.2" ILI9341
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
disp2 = ili9341.ILI9341(
spi,
cs=cs2_pin,
dc=dc2_pin,
rst=reset_pin2,
baudrate=BAUDRATE,
# pylint: enable=line-too-long
# Create blank image for drawing.
# Make sure to create image with mode 'RGB' for full color.
if disp.rotation % 180 == 90:
height = disp.width # we swap height/width to rotate it to landscape!
width = disp.height
else:
width = disp.width # we swap height/width to rotate it to landscape!
height = disp.height
image = Image.new("RGB", (width, height))
if disp2.rotation % 180 == 90:
height2 = disp2.width # we swap height/width to rotate it to landscape!
width2 = disp2.height
else:
width2 = disp2.width # we swap height/width to rotate it to landscape!
height2 = disp2.height
image2 = Image.new("RGB", (width2, height2))
print('width2:', width2, 'height2:', height2)
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
draw2 = ImageDraw.Draw(image2)
# Draw a white filled box as the background
draw.rectangle((00, 0, disp.width+100, disp.height+100), fill=(225, 225, 225))
disp.image(image)
input('draw blue box on second screen only')
#Draw a blue box only on the second screen
draw2.rectangle((0, 0, disp2.width+100, disp2.height+100), fill=(0, 225, 225))
disp2.image(image2)
I'm not sure if I'm doing something wrong with the chip selects/setup, or if this library just can't support multiple SPI devices. Thanks!
