I am using Arduino MKR1500 with the adafruit fingerprint sensor
I have a couple of questions about the adafruit fingerprint sensor:
1. are the fingerprints locally stored on the fingerprint sensor?
2. How many bytes does storing a fingerprint sensor require?
3. Is there a way I could get the fingerprint signatures and store it in the Arduino?
4. is there a way I could pull the fingerprint signatures from the sensor and send it over to the cloud using NB-IoT?
Any help is greatly appreciated.
Adafruit fingerprint sensor signatures
- mikeysklar
Re: Adafruit fingerprint sensor signatures
The fingerprint sensor (product id#751) stores the fingerprints in flash. I believe it comes to 534 bytes per print if I am reading the manual correctly.
There are some details around your area of interest on page 10 of the user manual.
https://cdn-shop.adafruit.com/datasheet ... ualV15.pdf
We have a pretty extensive thread on people trying to copy off the fingerprint to their own DB. It is actually the longest thread I have ever seen in the forums and at the end there looks like some working code was dropped in:
viewtopic.php?f=22&t=33229
4.3 Fingerprint Library
Synstem sets aside a certain space within Flash for fingerprint template storage, that¡s fingerprint library. Contents of the library remain at power off.
Capacity of the library changes with the capacity of Flash, system will recognize the latter automatically. Fingerprint template¡s storage in Flash is in sequential order. Assume the fingerprint capacity N, then the serial number of template in library is 0, 1, 2, 3 ¡ N. User can only access library by template number.
4.2 Buffer
There are an image buffer and two 512-byte-character-file buffer within the RAM space of the module. Users can read & write any of the buffers by instructions.
Note: Contents of the above buffers will be lost at power-off.
4.2.1 Image buffer
ImageBuffer serves for image storage and the image format is 256*288 pixels.
When transferring through UART, to quicken speed, only the upper 4 bits of the pixel is transferred (that is 16 grey degrees). And two adjacent pixels of the same row will form a byte before the transferring. When uploaded to PC, the 16-grey-degree image will be extended to 256-grey-degree format. That¡s 8-bit BMP format.
When transferring through USB, the image is 8-bit pixel, that¡s 256 grey degrees.
4.2.2 Character file buffer
Character file buffer, CharBuffer1, CharBuffer2, can be used to store both character file and template file.
- dkanday
Thanks mikeysklar!
- dkanday
Can some one please explain what does this piece of code do. I am trying to modify it for my project:
uint8_t fingerTemplate[512]; // the real template
memset(fingerTemplate, 0xff, 512);
// filtering only the data packets
int uindx = 9, index = 0;
while (index < 534) {
while (index < uindx) ++index;
uindx += 256;
while (index < uindx) {
fingerTemplate[index++] = bytesReceived[index];
uindx += 2;
uindx = index + 9;
for (int i = 0; i < 512; ++i) {
//Serial.print("0x");
printHex(fingerTemplate[i], 2);
//Serial.print(", ");
Serial.println("\ndone.");
//print the fingerprint template
void printHex(int num, int precision) {
char tmp[16];
char format[128];
sprintf(format, "%%.%dX", precision);
sprintf(tmp, format, num);
Serial.print(tmp);
