I checked every function with Teensy4.1, it works great.
But only one thing I failed, it is a bitmap.
When I try to upload the bitmap from the SD card, it fails due to the library.
I succeeded with Arduino Uno R3, but it doesn't work with Teensy 4.1.
I don't know how to fix it.
Please help me to fix this.
A bitmap is not compatible
- charlesbang
- Attachments
- error.jpg (164.91 KiB) Viewed 110 times
- dastels
Re: A bitmap is not compatible
This is a compile failure, apparently due to misconfiguration in SdFatConfig.h
- charlesbang
How can I solve this problem?dastels wrote:This is a compile failure, apparently due to misconfiguration in SdFatConfig.h
- dastels
I haven't run into this before, so I don't know. That said, I'd probably try setting the mentioned settings to 1 and see what happens.
