I am looking to 'chain' few NeoPixel Jewel - 7 x 5050 RGB LED and while I looked on the following image:
https://cdn-shop.adafruit.com/970x728/2226-04.jpg I see that there are two ground holes,
but in the following image I see you used only one "hole" for soldering the ground wire https://cdn-learn.adafruit.com/assets/a ... 1444245144
Therefore, do I need to solder the ground line into one “hole” like you do with the 5V or in using the two "holes?
How to solder solder few NeoPixel Jewel - 7 x 5050 RGB LED
- elyraz
- adafruit_support_bill
Re: How to solder solder few NeoPixel Jewel - 7 x 5050 RGB L
Both ground holes are connected together on the board. So it doesn't matter if you use just one or both. Whatever is more convenient for you.
