Neopixel 5mm Diffused LED Thru-hole PCB Footprint?
jrsteensen
Post by jrsteensen »
Looking at the diffused LED for a edge-lighting solution for some gauges on the flight simulator I am designing. I intend to PCB mount them, but the lead spacing and width on the diagram is a tad confusing. It appears there are missing dimensions to be able to fully define the PCB footprint. Would someone be willing to explain it a little better?
https://www.adafruit.com/product/1938#technical-details
Franklin97355
Re: Neopixel 5mm Diffused LED Thru-hole PCB Footprint?
Post by Franklin97355 »
Thanks for posting, according to the product page:
We don't have a datasheet for the LEDs themselves yet, see the photos above for the pinouts.
The leads are flexible. The spacing starts at 1.1mm (0.04") but we were able to bend them as needed.
but I'll see if there is any more info.
jrsteensen
NeoPixel 5mm TH.PNG (186.81 KiB) Viewed 77 times
See the highlighted dimensions for what I believe the pin spacing and size should be. Also, what are the dimensions of the bosses on the pin to set the height of the LED above the PCB? (The little rectangles on the pin.)
EDIT: If you can't dig anything more up, I'll just buy a set and break out the calipers and send you an updated drawing and MCAD model.
