I want to Attach 3 LED Panels to My Cheesehead and I need so
Don00_7
Post by Don00_7 »
Hi everyone i am new and was wondering if you all could give me some suggestions on how i could go about making this project into a reality. I made this cheese head for my daughter as she plays hockey in college and would like to put 3 LED panels on the cheese head. I would like to find a controller where i can have pre programmed messages either static or scrolling going through the three panels that can be accessed easily through a press of a button.
If you have any suggestions on controllers, power supplies, and flexible panels that would be much appreciated.
Thank you and ill share updates with photos
(The C
adafruit_support_mike
Re: I want to Attach 3 LED Panels to My Cheesehead and I nee
I'm afraid we don't have anything preassembled and preprogrammed. We have the pieces to make something like that, but working with them is a hands-on process.
For a wearable project, I'd suggest using NeoPixel matrices instead of standard RGB matrices. They're lighter and will use less power:
https://www.adafruit.com/?q=neomatrix&sort=BestMatch
The 8x32 flexible NeoMatrix would be lightest and easiest to install:
https://www.adafruit.com/product/2294
You could control that with a board as small as the Trinket M0:
https://www.adafruit.com/product/3500
Don00_7
Post by Don00_7 »
Hey,
I am getting this error when using the parts listed above -
main.py output:
File "main.py", line 3, in <module>
File "adafruit_pixel_framebuf.py", line 43, in <module>
File "adafruit_framebuf.py", line 84, in <module>
MemoryError: memory allocation failed, allocating 136 bytes
My code so far is :
import board
import neopixel
from adafruit_pixel_framebuf import PixelFramebuffer
pixel_pin = board.D4
pixel_width = 32
pixel_height = 8
pixels = neopixel.NeoPixel(
pixel_pin,
pixel_width * pixel_height,
brightness=0.1,
auto_write=False,
pixel_framebuf = PixelFramebuffer(
pixels,
32,
8
pixel_framebuf.fill(0x0000FF)
pixel_framebuf.display()
What does this error mean? I have 5KB free so 136 bytes shouldn't be a problem...? I am thinking however the trinket m0 might be too small for the recommended parts. I am using the set up procedure - https://learn.adafruit.com/easy-neopixe ... uf-library listed on adafruit(your?) website. This set up doc does recommend the M4 processor i believe.
Lastly for convenience these are the libraries I am using based on my understanding of the set up procedure.
adafruit_pixel_framebuf.mpy
adafruit_framebuf.mpy
adafruit_led_animation
neopixel.mpy
However I also added adafruit_pypixelbuf.mpy because I was getting an import error without it.
