Hi All,
I’ve been using multiple Adafruit 2.4” displays on SPI. I have managed to configure six of them on the same SPI bus which all work, but as soon as I add a 7th, the code won’t compile.
The displays are initialised as follows and as soon as I uncomment tft7 it stops compiling.
Is the library limited to 6 actual devices?
// Configure ILI9341 display.
Adafruit_ILI9341 tft1 = Adafruit_ILI9341(TFT1_CS, TFT1_DC);
Adafruit_ILI9341 tft2 = Adafruit_ILI9341(TFT2_CS, TFT2_DC);
Adafruit_ILI9341 tft3 = Adafruit_ILI9341(TFT3_CS, TFT3_DC);
Adafruit_ILI9341 tft4 = Adafruit_ILI9341(TFT4_CS, TFT4_DC);
Adafruit_ILI9341 tft5 = Adafruit_ILI9341(TFT5_CS, TFT5_DC);
Adafruit_ILI9341 tft6 = Adafruit_ILI9341(TFT6_CS, TFT6_DC);
//Adafruit_ILI9341 tft7 = Adafruit_ILI9341(TFT7_CS, TFT7_DC);
//Adafruit_ILI9341 tft8 = Adafruit_ILI9341(TFT8_CS, TFT8_DC);
Adafruit ili9341 Library
- mikeysklar
Re: Adafruit ili9341 Library
Good job getting six TFTs going. Even that seems impressive.
What is the compile error you receive when the 7th display is initialized? It might be helpful to enable verbose debugging.
File->Preferences->Show verbose output during....
- Chris_Cooper
Sorry for the lack of reply, I may have been premature on the 6TFTs as it is very unstable.
Just solving that then I will come back to you!
- mikeysklar
Okay, let us know if we can help with the six TFTs getting stable.
- Chris_Cooper
Please see next post.
- Chris_Cooper
So, after much reading, running 8 TFTs is not going to work seemingly. So my project is in jeopardy, as it’s based on 8 displays. But I suddenly thought that perhaps I could use both the VSPI and HSPI bus's on my ESP32 to run 4 TFTs each?!
Therefore, I was wondering if have any hints on how to use the Adafruit ILI9341 driver with the ESP32 in this configuration?
I’m trying to get my head around SPI classes and the ILI9341 Adafruit Driver, but I can’t get the HSPI bus to initialise although the VSPI bus is fine.
When using this line of code, on the default SPI bus, the display works fine (testing circuit):
However, to use the ILI9341 on the HSPI bus, I think I call it as follows:
Then I call the display driver, but with less parameters:
But this doesn't allow me to configure the other pins (MOSI, CLK etc) and therefore how / where are these set?
Regards,
Christopher
Adafruit_ILI9341 tft1 = Adafruit_ILI9341(VSPI_CS, VSPI_DC, VSPI_MOSI, VSPI_CLK, VSPI_RST, VSPI_MISO);
SPIClass SPI2 = SPIClass(HSPI);
Adafruit_ILI9341 tft2 = Adafruit_ILI9341(&SPI2, HSPI_DC, HSPI_CS, HSPI_RST);
Regards,
Christopher
- Chris_Cooper
This is the complete test sketch.
#include <SPI.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_GFX.h>
#define VSPI_MISO 19 // MISO
#define VSPI_MOSI 23 // MOSI
#define VSPI_CLK 18 // SCK
#define VSPI_CS 5 // CS
#define VSPI_DC 4 // DC
#define VSPI_RST 22 // RST
#define HSPI_MISO 12
#define HSPI_MOSI 13
#define HSPI_CLK 14
#define HSPI_CS 15
#define HSPI_DC 26
#define HSPI_RST 27 // RST
#define BLUE 0x001F
#define TEAL 0x0438
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define ORANGE 0xFD20
#define PINK 0xF81F
#define PURPLE 0x801F
#define GREY 0xC618
#define WHITE 0xFFFF
#define BLACK 0x0000
// VSPI (default under Arduino)
SPIClass SPI1(VSPI);
Adafruit_ILI9341 tft1=Adafruit_ILI9341(&SPI1, VSPI_DC, VSPI_CS, VSPI_RST);
// HSPI
SPIClass SPI2(HSPI);
Adafruit_ILI9341 tft2=Adafruit_ILI9341(&SPI2, HSPI_DC, HSPI_CS, HSPI_RST);
pinMode(VSPI_CS, OUTPUT); //VSPI SS
pinMode(HSPI_CS, OUTPUT); //HSPI SS
SPI1.begin(VSPI_CLK, VSPI_MISO, VSPI_MOSI, VSPI_CS);
SPI2.begin(HSPI_CLK, HSPI_MISO, HSPI_MOSI, HSPI_CS);
tft1.begin();
tft1.setRotation(3);
tft1.setCursor(0, 0);
tft1.fillScreen(BLUE);
delay(1000);
tft2.begin();
tft2.setRotation(3);
tft2.setCursor(0, 0);
tft2.fillScreen(GREEN);
- Chris_Cooper
I have now managed to get my 8 TFT's working by diving them across both the VSPI and HSPI ESP32 BUS's.
Using your Adafruit ILI9341 driver, I set the SS (Chip Select) pin when calling the driver to a dummy pin as follows:
I then use digital writes to enable or disable each of the actual SS (Chip Select) pins when required, which works a treat.
My only concern now is that the speed and performance is fairly slow.
Full test sketch here for anyone wanting to run many TFTs of the same type.
// VSPI Class
Adafruit_ILI9341 tft1 = Adafruit_ILI9341(VSPI_CS0, VSPI_DC, VSPI_MOSI, VSPI_CLK, VSPI_RST, VSPI_MISO); // CS0 is a dummy pin
// HSPI Class
Adafruit_ILI9341 tft2 = Adafruit_ILI9341(HSPI_CS9, HSPI_DC, HSPI_MOSI, HSPI_CLK, HSPI_RST, HSPI_MISO); // CS9 is a dummy pin
#include <SPI.h>
#include "startScreen.h"
#define VSPI_MISO 19 // MISO - Not needed as it is a display
#define VSPI_CS0 36 // This is set to an erroneous pin as to not confuse manual chip selects using digital writes.
#define VSPI_CS1 5 // Screen one chip select
#define VSPI_CS2 21 // Screen two chip select
#define VSPI_CS3 16 // Screen three chip select
#define VSPI_CS4 17 // Screen four chip select
#define HSPI_MISO 12 // MISO - Not needed as it is a display
#define HSPI_MOSI 13 // MOSI
#define HSPI_CLK 14 // SCK
#define HSPI_DC 26 // DC
#define HSPI_CS9 39 // This is set to an erroneous pin as to not confuse manual chip selects using digital writes.
#define HSPI_CS5 15 // Screen five chip select
#define HSPI_CS6 25 // Screen six chip select
#define HSPI_CS7 33 // Screen seven chip select
#define HSPI_CS8 32 // Screen eight chip select
#define BLUE 0x001F
#define TEAL 0x0438
#define CYAN 0x07FF
#define RED 0xF800
#define PINK 0xF81F
#define GREY 0xC618
// VSPI Class
// HSPI Class
// Enable output pins for chip selects.
pinMode(VSPI_CS1, OUTPUT); //VSPI SS
pinMode(VSPI_CS2, OUTPUT); //VSPI SS
pinMode(VSPI_CS3, OUTPUT); //VSPI SS
pinMode(VSPI_CS4, OUTPUT); //VSPI SS
pinMode(HSPI_CS5, OUTPUT); //HSPI SS
pinMode(HSPI_CS6, OUTPUT); //HSPI SS
pinMode(HSPI_CS7, OUTPUT); //HSPI SS
pinMode(HSPI_CS8, OUTPUT); //HSPI SS
// Set all tft1 chip select outputs high to ensure stable BUS
disableVSPIScreens();
// Set all tft1 chip select outputs low to configure all displays the same using tft.begin.
digitalWrite(VSPI_CS1, LOW);
digitalWrite(VSPI_CS2, LOW);
digitalWrite(VSPI_CS3, LOW);
digitalWrite(VSPI_CS4, LOW);
// Send screen configuration.
tft1.begin();
// Reset all chip selects high once again.
// Set all tft2 chip select outputs high to ensure stable BUS
disableHSPIScreens();
// Set all tft2 chip select outputs low to configure all displays the same using tft.begin.
digitalWrite(HSPI_CS5, LOW);
digitalWrite(HSPI_CS6, LOW);
digitalWrite(HSPI_CS7, LOW);
digitalWrite(HSPI_CS8, LOW);
tft2.begin();
// Bank one screen tests.
delay(250);
enableScreen1();
delay(250);
enableScreen2();
delay(250);
enableScreen3();
delay(250);
enableScreen4();
// Bank two screen tests.
delay(250);
enableScreen5();
delay(250);
enableScreen6();
delay(250);
enableScreen7();
delay(250);
enableScreen8();
delay(250);
enableScreen1();
tft1.fillScreen(RED);
tft1.setFont();
tft1.setTextSize(2);
tft1.setTextColor(BLACK);
tft1.setCursor(20, 150);
tft1.println("Screen One - Bank One");
enableScreen5();
tft2.fillScreen(RED);
tft2.setFont();
tft2.setTextSize(2);
tft2.setTextColor(BLACK);
tft2.setCursor(20, 150);
tft2.println("Screen Five - Bank Two");
enableScreen2();
drawBitmap(tft1, 48, 96, startScreen, 128, 128);
} // Close setup.
// Nothing here just yet!
} // Close loop.
// Disable outputs for all displays on VSPI bus.
void disableVSPIScreens() {
digitalWrite(VSPI_CS1, HIGH);
digitalWrite(VSPI_CS2, HIGH);
digitalWrite(VSPI_CS3, HIGH);
digitalWrite(VSPI_CS4, HIGH);
} // Close function.
// Disable outputs for all displays on HSPI bus.
void disableHSPIScreens() {
digitalWrite(HSPI_CS5, HIGH);
digitalWrite(HSPI_CS6, HIGH);
digitalWrite(HSPI_CS7, HIGH);
digitalWrite(HSPI_CS8, HIGH);
// Enable screen one on bank one to recieve SPI commands.
void enableScreen1() {
// Enable screen two on bank one to recieve SPI commands.
void enableScreen2() {
// Enable screen three on bank one to recieve SPI commands.
void enableScreen3() {
// Enable screen four on bank one to recieve SPI commands.
void enableScreen4() {
// Enable screen five on bank two to recieve SPI commands.
void enableScreen5() {
// Enable screen six on bank two to recieve SPI commands.
void enableScreen6() {
// Enable screen seven on bank two to recieve SPI commands.
void enableScreen7() {
// Enable screen eight on bank two to recieve SPI commands.
void enableScreen8() {
- Chris_Cooper
For anyone wanting to do this, the performance issue is now solved as I have moved the SPI bus's back to being hardware defined as follows:
Then you have to slow down the TFT displays as follows:
// VSPI Class (default).
Adafruit_ILI9341 tft1 = Adafruit_ILI9341(VSPI_CS0, VSPI_DC, VSPI_RST); // CS0 is a dummy pin
//Software defined SPI.
//Adafruit_ILI9341 tft1 = Adafruit_ILI9341(VSPI_CS0, VSPI_DC, VSPI_MOSI, VSPI_CLK, VSPI_RST, VSPI_MISO); // CS0 is a dummy pin
// HSPI Class.
Adafruit_ILI9341 tft2 = Adafruit_ILI9341(&SPI2, HSPI_DC, HSPI_CS9, HSPI_RST); // CS9 is a dummy pin
//Adafruit_ILI9341 tft2 = Adafruit_ILI9341(HSPI_CS9, HSPI_DC, HSPI_MOSI, HSPI_CLK, HSPI_RST, HSPI_MISO); // CS9 is a dummy pin
tft1.begin(27000000);
- mikeysklar
Many thanks and congrats on getting all 8 TFTs going. That is awesome. Appreciate the code, CS trick and SPI slowdown freq.
