Neopixel strips have sometimes wrong colours
mouha
Post by mouha »
Here is the context of my issue :
  • * I've bought 3 x 1507 (144 rgb ) which I cut to have 6.
    * I've connected all of them to a fadecandy and to a 5V/5A wall power supply.
    * I'm using the test patterns from the FC server page.
The issue : 3 strips are properly display white colors, some of the others are displaying some colors (randomly) and some nothing.
So I've used another FC to check that it's not the problem with only 2 strips.
Same : the strip that was ok is still ok , and one of the wrong strip still wrong.
The picture shows it well:
  • with no pattern some weird colors for the bad strip + 1 led (!!) for the good one
    with 50% pattern : the good diplays everything properly + the wrong is not changing
no pattern.jpg (134.52 KiB) Viewed 284 times
dastels
Re: Neopixel strips have sometimes wrong colours
Post by dastels »
Did you test them before cutting them?
Have you double and tribble checked your wiring? Specifically the connection at the end of the strip.
mouha
Post by mouha »
I just checked 1 from the 3.
Not only I've checked the wiring but 2 of them have been removed to be re-wired to another Fade Candy.
These are the one you can see on the picture.
mouha
Post by mouha »
Is there something that can be done to get the strips working ?
dastels
Post by dastels »
I would test each (half) strip with a simple test. One of the neopixel examples will do. No fade candy, just a simple board (even an Arduino UNO should do) to test the basic function of each strip. Describe precisely how the problematic strinps behave.
mouha
Post by mouha »
I don't have Arduino. what is possible to do with a PI please ?
dastels
Post by dastels »
Try the example code in this guide:
https://learn.adafruit.com/neopixels-on-raspberry-pi/raspberry-pi-wiring
mouha
Post by mouha »
Last question : but what if after the half that have been cut : it still doesn't work properly while testing like you propose ?
I've been reading the Uberguide / tech detail / etc . and I understood that it was easily possible to cut a strip to make 2 .
I never found anything to set a common ground between the power supply and the strip when using the FC so ...
dastels
Post by dastels »
Yes, cutting them should not cause a problem. Hmm.. can you post clear, closeups of the ends where you chut, and where you've connected to the resulting strips.
Hmm again, the half strips that are causing a problem.. are you connecting to a cut end on them as opposed to the original wired end?
mouha
Post by mouha »
Some close up from these strips.
Each strip have been cut around its middle for some strips, and 65 or 66 Neopixels for others . Because the FC manage up to 64 I did this.
Thus, each strip is soldered to the FC by using the existent connector part, not from the cut side of it.
dastels
Post by dastels »
OK. Each end of the strips is different. One end has Data-in... the other has data-out. You need to connect to the data-in sides. So in half the cases, that will be the cut end.
mouha
Post by mouha »
I see, indeed the one that doesn't works has the arrows in a reversed way.
So : is it enough to switch the 2 data wires of this strip from the FC ?
dastels
Post by dastels »
Connecting the data from the FC to the Data-in of the strip will probably fix your problem barring anything other issues, though no damage should have been done by the connection to Data-out.
mouha
Post by mouha »
I have retry all the strips that were blank, by reversing the 2 wires (white & black) : none of them worked.
Does this means that if you just reverse these 2 wires, the strip get damaged all the time ?
dastels
Post by dastels »
Why did you do that? black is ground and white is signal (generally)... is that how they are connected on the FC?
You nned to connect the data signals from the FC to the Data-in end of the strips. As you say, there are arrows that indicate the flow of data through the strip. The arrows point from the Data-in end to the Data-out end.
