I have a raspberry pi B+ and a PiTFT - Assembled 320x240 2.8" TFT resistive.
Os is: Linux raspberrypi 5.10.60+ #1449 Wed Aug 25 14:59:20 BST 2021 armv6l GNU/Linux
When I try to run the adafruit-pitft.py script, in interactive mode, at the end I get this error:
PITFT Checking init system...
Found systemd
/boot is mounted
PITFT System update
Updating apt indexes............
PITFT Apt failed to update indexes!
Is there anything I can do?
"PITFT Apt failed to update indexes" error on Tft install
- Deadflag8
Re: "PITFT Apt failed to update indexes" error on Tft instal
I also have this exact same issue
If anyone is interested, I solved the issue manually running the command
sudo apt update
(that's what the .py script was doing).
The display is now running fine.
sudo apt update
- CasBleach
Yep, that fixed the issue for me too. Specifically, using your suggestion and then running the install script again, and voila!
Thank you!
Thank you!
