Hey Adafruit!
I recently purchased a pair of 32x32 LED panels (ID:1484). I noticed as I was opening them up that on one of the chips on the back, some of the solder had flowed together and was branched a pair of chip connectors. Should I try to desolder and fix this myself or is there something you all can suggest on this? Thanks! Image of issue attached
32x32 Matrix Chip Soldering Issue
- borisv
- Attachments
- IMG_1224.jpg (509.56 KiB) Viewed 126 times
- dastels
Re: 32x32 Matrix Chip Soldering Issue
I don't see that you say it, but you imply that this is just one of of the boards? A quick touch with a soldering iron and solder wick (or even without wick if you pull straight away from the chip with a clean iron tip) should clean it up. That'll save the wait for another display to be shipped. If that doesn't do the job we'll do something else.
- adafruit2
the pads are connected together, its fine
- borisv
Thanks for the replies, everyone. I looked at both the boards and they are indeed connected. I appreciate your getting back to me to confirm, though.
