Building Custom DotStar Strip Matrix 47 X 5 — ZigZag Direct
PFO
Post by PFO »
I'm building a 47 x 5 LED matrix using the 60 LED/m warm white DotStar LED strip.
Looking through the library, I saw that you can configure a progressive or zigzag layout, so when I cut and soldiered my strips together, I wired them in a zigzag configuration (because I like the aesthetics of the strips being "right" side up.
Using the strand test, only the first row is lighting up. Did I misunderstand the capabilities? Do I need to re-solder my connections, reversing every other row?
IMG_4616 copy.jpg (296.64 KiB) Viewed 168 times
XRAD
Re: Building Custom DotStar Strip Matrix 47 X 5 — ZigZag Di
Post by XRAD »
looks like you have dataOUT 1st row going to dataOUT on second row..hard to tell....
what's your code? you can use a 5x47(or how ever many you pixels have) matrix code....
for example, this fastLEd code uses a serpentine layout like you have....
#include <FastLED.h>
#define LED_PIN     12
#define BRIGHTNESS  20
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
const uint8_t kMatrixWidth  = 16;
const uint8_t kMatrixHeight = 16;
const bool    kMatrixSerpentineLayout = true;
// This example combines two features of FastLED to produce a remarkable range of
// effects from a relatively small amount of code.  This example combines FastLED's
// color palette lookup functions with FastLED's Perlin/simplex noise generator, and
// the combination is extremely powerful.
// You might want to look at the "ColorPalette" and "Noise" examples separately
// if this example code seems daunting.
// The basic setup here is that for each frame, we generate a new array of
// 'noise' data, and then map it onto the LED matrix through a color palette.
// Periodically, the color palette is changed, and new noise-generation parameters
// are chosen at the same time.  In this example, specific noise-generation
// values have been selected to match the given color palettes; some are faster,
// or slower, or larger, or smaller than others, but there's no reason these
// parameters can't be freely mixed-and-matched.
// In addition, this example includes some fast automatic 'data smoothing' at
// lower noise speeds to help produce smoother animations in those cases.
// The FastLED built-in color palettes (Forest, Clouds, Lava, Ocean, Party) are
// used, as well as some 'hand-defined' ones, and some proceedurally generated
// palettes.
#define NUM_LEDS (kMatrixWidth * kMatrixHeight)
#define MAX_DIMENSION ((kMatrixWidth>kMatrixHeight) ? kMatrixWidth : kMatrixHeight)
// The leds
CRGB leds[kMatrixWidth * kMatrixHeight];
// The 16 bit version of our coordinates
static uint16_t x;
static uint16_t y;
static uint16_t z;
// We're using the x/y dimensions to map to the x/y pixels on the matrix.  We'll
// use the z-axis for "time".  speed determines how fast time moves forward.  Try
// 1 for a very slow moving effect, or 60 for something that ends up looking like
// water.
uint16_t speed = 100; // speed is set dynamically once we've started up
// Scale determines how far apart the pixels in our noise matrix are.  Try
// changing these values around to see how it affects the motion of the display.  The
// higher the value of scale, the more "zoomed out" the noise iwll be.  A value
// of 1 will be so zoomed in, you'll mostly see solid colors.
uint16_t scale = 100; // scale is set dynamically once we've started up
// This is the array that we keep our computed noise values in
uint8_t noise[MAX_DIMENSION][MAX_DIMENSION];
CRGBPalette16 currentPalette( PartyColors_p );
uint8_t       colorLoop = 1;
  delay(3000);
  LEDS.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS);
  LEDS.setBrightness(BRIGHTNESS);
  // Initialize our coordinates to some random values
  x = random16();
  y = random16();
  z = random16();
// Fill the x/y array of 8-bit noise values using the inoise8 function.
void fillnoise8() {
  // If we're runing at a low "speed", some 8-bit artifacts become visible
  // from frame-to-frame.  In order to reduce this, we can do some fast data-smoothing.
  // The amount of data smoothing we're doing depends on "speed".
  uint8_t dataSmoothing = 0;
  if ( speed < 50) {
    dataSmoothing = 200 - (speed * 4);
  for (int i = 0; i < MAX_DIMENSION; i++) {
    int ioffset = scale * i;
    for (int j = 0; j < MAX_DIMENSION; j++) {
      int joffset = scale * j;
      uint8_t data = inoise8(x + ioffset, y + joffset, z);
      // The range of the inoise8 function is roughly 16-238.
      // These two operations expand those values out to roughly 0..255
      // You can comment them out if you want the raw noise data.
      data = qsub8(data, 16);
      data = qadd8(data, scale8(data, 39));
      if ( dataSmoothing ) {
        uint8_t olddata = noise[i][j];
        uint8_t newdata = scale8( olddata, dataSmoothing) + scale8( data, 256 - dataSmoothing);
        data = newdata;
      noise[i][j] = data;
  z += speed;
  // apply slow drift to X and Y, just for visual variation.
  x += speed / 8;
  y -= speed / 16;
void mapNoiseToLEDsUsingPalette()
  static uint8_t ihue = 0;
  for (int i = 0; i < kMatrixWidth; i++) {
    for (int j = 0; j < kMatrixHeight; j++) {
      // We use the value at the (i,j) coordinate in the noise
      // array for our brightness, and the flipped value from (j,i)
      // for our pixel's index into the color palette.
      uint8_t index = noise[j][i];
      uint8_t bri =   noise[i][j];
      // if this palette is a 'loop', add a slowly-changing base value
      if ( colorLoop) {
        index += ihue;
      // brighten up, as the color palette itself often contains the
      // light/dark dynamic range desired
      if ( bri > 127 ) {
        bri = 255;
      } else {
        bri = dim8_raw( bri * 2);
      CRGB color = ColorFromPalette( currentPalette, index, bri);
      leds[XY(i, j)] = color;
  ihue += 1;
  // Periodically choose a new palette, speed, and scale
  ChangePaletteAndSettingsPeriodically();
  //myPalette();
  //myPalette1();
  // generate noise data
  fillnoise8();
  // convert the noise data to colors in the LED array
  // using the current palette
  mapNoiseToLEDsUsingPalette();
  LEDS.show();
  // delay(10);
// There are several different palettes of colors demonstrated here.
// FastLED provides several 'preset' palettes: RainbowColors_p, RainbowStripeColors_p,
// OceanColors_p, CloudColors_p, LavaColors_p, ForestColors_p, and PartyColors_p.
// Additionally, you can manually define your own color palettes, or you can write
// code that creates color palettes on the fly.
// 1 = 5 sec per palette
// 2 = 10 sec per palette
// etc
#define HOLD_PALETTES_X_TIMES_AS_LONG 1
void myPalette() {
  currentPalette = OceanColors_p;           speed = 2; scale = 30; colorLoop = 0;
void myPalette1() {
  SetupBlackAndWhiteStripedPalette();       speed = 2; scale = 30; colorLoop = 1;
void ChangePaletteAndSettingsPeriodically()
  uint8_t secondHand = ((millis() / 5000) / HOLD_PALETTES_X_TIMES_AS_LONG) % 60;
  static uint8_t lastSecond = 99;
  if ( lastSecond != secondHand) {
    lastSecond = secondHand;
    if ( secondHand ==  0)  {
      currentPalette = RainbowColors_p;
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand ==  5)  {
      SetupPurpleAndGreenPalette();
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand == 10)  {
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand == 15)  {
      currentPalette = ForestColors_p;
      speed =  2;
      scale = 30;
      colorLoop = 0;
    if ( secondHand == 20)  {
      currentPalette = CloudColors_p;
      speed =  2;
      scale = 30;
      colorLoop = 0;
    if ( secondHand == 25)  {
      currentPalette = LavaColors_p;
      speed =  2;
      scale = 30;
      colorLoop = 0;
    if ( secondHand == 30)  {
      speed = 2;
      scale = 30;
      colorLoop = 0;
    if ( secondHand == 35)  {
      currentPalette = PartyColors_p;
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand == 40)  {
      SetupRandomPalette();
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand == 45)  {
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand == 50)  {
      speed = 2;
      scale = 30;
      colorLoop = 1;
    if ( secondHand == 55)  {
      currentPalette = RainbowStripeColors_p;
      speed = 2;
      scale = 30;
      colorLoop = 1;
// This function generates a random palette that's a gradient
// between four different colors.  The first is a dim hue, the second is
// a bright hue, the third is a bright pastel, and the last is
// another bright hue.  This gives some visual bright/dark variation
// which is more interesting than just a gradient of different hues.
void SetupRandomPalette()
  currentPalette = CRGBPalette16(
                     CHSV( random8(), 255, 32),
                     CHSV( random8(), 255, 255),
                     CHSV( random8(), 128, 255),
                     CHSV( random8(), 255, 255));
// This function sets up a palette of black and white stripes,
// using code.  Since the palette is effectively an array of
// sixteen CRGB colors, the various fill_* functions can be used
// to set them up.
void SetupBlackAndWhiteStripedPalette()
  // 'black out' all 16 palette entries...
  fill_solid( currentPalette, 16, CRGB::Black);
  // and set every fourth one to white.
  currentPalette[0] = CRGB::White;
  currentPalette[4] = CRGB::White;
  currentPalette[8] = CRGB::White;
  currentPalette[12] = CRGB::White;
// This function sets up a palette of purple and green stripes.
void SetupPurpleAndGreenPalette()
  CRGB purple = CHSV( HUE_PURPLE, 255, 255);
  CRGB green  = CHSV( HUE_GREEN, 255, 255);
  CRGB black  = CRGB::Black;
                     green,  green,  black,  black,
                     purple, purple, black,  black,
                     purple, purple, black,  black );
// Mark's xy coordinate mapping code.  See the XYMatrix for more information on it.
uint16_t XY( uint8_t x, uint8_t y)
  uint16_t i;
  if ( kMatrixSerpentineLayout == false) {
    i = (y * kMatrixWidth) + x;
  if ( kMatrixSerpentineLayout == true) {
    if ( y & 0x01) {
      // Odd rows run backwards
      uint8_t reverseX = (kMatrixWidth - 1) - x;
      i = (y * kMatrixWidth) + reverseX;
    } else {
      // Even rows run forwards
  return i;
