I just got the 2.8" TFT (part no. 1947) delivered and after plugging it into my Arduino Uno R3 board, I only see a white screen.
I've installed v1.10.12 of the Adafruit GFX library and v1.5.9 of the ILI9341 library and when trying any of the examples I see output on the serial console but the TFT display stays white.
I believe this should work out of the box w/o any changes needs to the shield. Is it busted?
2.8 TFT Capacitive Touch Shield issues with Arduino Uno
- idlethread
- idlethread
Re: 2.8 TFT Capacitive Touch Shield issues with Arduino Uno
@adafruit_support_bill, @adafruit, any help here?
- adafruit2
can you post a photo of the two products and how they're connected + soldering? they should work.
- idlethread
@adafruit2, please find images attached. No soldering involved since this is an Arduino Uno R3.
- adafruit2
ok please run an i2c scan and post the output, that will test power/tft connection
https://learn.adafruit.com/scanning-i2c-addresses
- idlethread
adafruit2 wrote:ok please run an i2c scan and post the output, that will test power/tft connection
I used the code on https://learn.adafruit.com/scanning-i2c ... es/arduino and got the following output:
Scanning...
I2C device found at address 0x38 !
done
- idlethread
@adafruit2 anything else I can try? ^^^^
