I bought 4 units of this TFT display on 29.9.2021, since then I had to wait for other parts to arrive before I could try to test them.
I've connected 2 displays to 2 cameras individually and i do get a clear picture on both, now here's the issue,
When ever i turn on the displays one of the display is way more bright then the other, i've noticed that when i press the button that flips the image the brightness issue disappear and both displays show the same brightness picture, how ever when i turn off the power the flip settings and brightness doesn't save and the issue show again.
How can this issue be fixed?
NTSC/PAL (Television) TFT Display - 2.0" Diagonal
- benpru
- mikeysklar
Re: NTSC/PAL (Television) TFT Display - 2.0" Diagonal
Interesting looking goggles application.
What voltage are you powering the displays at? The two solutions I've come across on these screens are:
1) ribbon cable needs reseating
2) voltage needs to be a regulated ~9v
It's good to know the button with 5 level of brightness adjustment is a work around. I suppose you could always breakout access to the button if nothing else worked, but ribbon and voltage should be explored first.
- neiloler
That looks like a very familiar project, as I'm building the single monocular version there of.
I was under the impression due to the specs provided on the Adafruit product page that 12v was okay to power?
I'm powering this with a regulated 11.5V.
Does this account for why I burned this thing out?
See: viewtopic.php?f=47&t=184455
- mikeysklar
@neiloler - I like the monocle idea. The displays are rated for 6 - 12v. If the regulator was getting hot with 11.5v that might be a sign of needing more heat sink capacity or running at a lower voltage to keep things optimal. I had come across a post while looking for @benpru's brightness issue and came across the 9v regulated voltage suggestion for smoothing out brightness.
@benpru - I believe there is a dual LED and single LED form of this display. Can you confirm which ones you have? This post might help illustrate. My thought is that you might have two different types.
viewtopic.php?f=51&t=184699&p=896173&hi ... sc#p896173
- benpru
The issue is that when I power on the unit the color is different, when I press the button that flips the screen then the color is normal, not the brightness button.mikeysklar wrote:Interesting looking goggles application.
I've tried using 7.4V and the results are the same, so I doubt that the issue is voltage regulator, i will try to install a different display, maybe I got a faulty one....
- benpru
i've checked 2 more displays, 3 out of 4 displays are working perfectly.
The one display i made this post about is 100% defective, how do i get a replacement?
- mikeysklar
@benpru,
It looks like you opened the forum discussion within the 30-day warrany window so please contact [email protected] requesting a replacement for the one display that is an issue. They will need a link to this forum thread and your order#.
- neiloler
Did you get your project up and running? I got a new screen, and now I find that it works, but I can't get the image flip settings to stick, the reset upon power cycle.
Is this normal with this controller board for the screen?
