I'm using a Raspberry Pi 3 A+ with the latest Raspberry Pi OS and want to make sure the software is correctly installed so I've been trying to follow the instructions exactly here:
https://learn.adafruit.com/neopixels-on ... thon-usage
which in turn says to follow these instructions first:
https://learn.adafruit.com/circuitpytho ... rypi-linux
the very last step on the Python Usage page is to run
sudo python3 -m pip install --force-reinstall adafruit-blinka
This fails with various errors.
There's a note in the instructions about "If your default Python is version 3 you may need to run 'pip' instead. "
I assume this means:
sudo pip install --force reinstall adafruit-blinka
which fails as well.
Any help in getting it to complete successfully would be appreciated.
Here is what it outputs:
pi@raspberrypi3A:~/Downloads $ sudo pip install --force-reinstall adafruit-blinka
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting adafruit-blinka
Using cached https://www.piwheels.org/simple/adafruit-blinka/Adafruit_Blinka-6.15.0-py3-none-any.whl (187 kB)
Collecting Adafruit-PureIO>=1.1.7
Using cached https://www.piwheels.org/simple/adafruit-pureio/Adafruit_PureIO-1.1.9-py3-none-any.whl (12 kB)
Collecting pyftdi>=0.40.0
Using cached https://www.piwheels.org/simple/pyftdi/pyftdi-0.53.3-py3-none-any.whl (141 kB)
Collecting sysv-ipc>=1.1.0
Using cached https://www.piwheels.org/simple/sysv-ipc/sysv_ipc-1.1.0-cp39-cp39-linux_armv7l.whl (63 kB)
Collecting Adafruit-PlatformDetect>=3.13.0
Using cached https://www.piwheels.org/simple/adafruit-platformdetect/Adafruit_PlatformDetect-3.17.2-py3-none-any.whl (19 kB)
Collecting RPi.GPIO
Using cached RPi.GPIO-0.7.0.tar.gz (30 kB)
Collecting rpi-ws281x>=4.0.0
Using cached https://www.piwheels.org/simple/rpi-ws281x/rpi_ws281x-4.3.1-cp39-cp39-linux_armv7l.whl (117 kB)
Collecting pyusb!=1.2.0,>=1.0.0
Using cached https://www.piwheels.org/simple/pyusb/pyusb-1.2.1-py3-none-any.whl (58 kB)
Collecting pyserial>=3.0
Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Building wheels for collected packages: RPi.GPIO
Building wheel for RPi.GPIO (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-cnlqs2yi
cwd: /tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/
Complete output (87 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.9
creating build/lib.linux-armv7l-3.9/RPi
copying RPi/__init__.py -> build/lib.linux-armv7l-3.9/RPi
creating build/lib.linux-armv7l-3.9/RPi/GPIO
copying RPi/GPIO/__init__.py -> build/lib.linux-armv7l-3.9/RPi/GPIO
running build_ext
building 'RPi._GPIO' extension
creating build/temp.linux-armv7l-3.9
creating build/temp.linux-armv7l-3.9/source
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/c_gpio.c -o build/temp.linux-armv7l-3.9/source/c_gpio.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/common.c -o build/temp.linux-armv7l-3.9/source/common.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/constants.c -o build/temp.linux-armv7l-3.9/source/constants.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-armv7l-3.9/source/cpuinfo.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/event_gpio.c -o build/temp.linux-armv7l-3.9/source/event_gpio.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/py_gpio.c -o build/temp.linux-armv7l-3.9/source/py_gpio.o
source/py_gpio.c: In function ‘PyInit__GPIO’:
source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations]
1046 | if (!PyEval_ThreadsInitialized())
In file included from /usr/include/python3.9/Python.h:145,
from source/py_gpio.c:23:
/usr/include/python3.9/ceval.h:129:36: note: declared here
129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void);
source/py_gpio.c:1047:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations]
1047 | PyEval_InitThreads();
/usr/include/python3.9/ceval.h:130:37: note: declared here
130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/py_pwm.c -o build/temp.linux-armv7l-3.9/source/py_pwm.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/soft_pwm.c -o build/temp.linux-armv7l-3.9/source/soft_pwm.o
arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,-z,relro -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.9/source/c_gpio.o build/temp.linux-armv7l-3.9/source/common.o build/temp.linux-armv7l-3.9/source/constants.o build/temp.linux-armv7l-3.9/source/cpuinfo.o build/temp.linux-armv7l-3.9/source/event_gpio.o build/temp.linux-armv7l-3.9/source/py_gpio.o build/temp.linux-armv7l-3.9/source/py_pwm.o build/temp.linux-armv7l-3.9/source/soft_pwm.o -o build/lib.linux-armv7l-3.9/RPi/_GPIO.cpython-39-arm-linux-gnueabihf.so
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:37: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:37: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:42: multiple definition of `both_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:42: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:41: multiple definition of `falling_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:41: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:40: multiple definition of `rising_edge'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:40: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:39: multiple definition of `pud_down'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:39: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:38: multiple definition of `pud_up'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:38: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:37: multiple definition of `pud_off'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:37: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:36: multiple definition of `bcm'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:36: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:35: multiple definition of `board'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:35: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:34: multiple definition of `unknown'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:34: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:33: multiple definition of `spi'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:32: multiple definition of `i2c'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:32: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:31: multiple definition of `serial'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:31: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:30: multiple definition of `pwm'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:30: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:29: multiple definition of `output'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:29: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:28: multiple definition of `input'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:28: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:27: multiple definition of `low'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:27: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:26: multiple definition of `high'; build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/constants.h:26: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/py_pwm.h:23: multiple definition of `PWMType'; build/temp.linux-armv7l-3.9/source/py_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/py_pwm.h:23: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:37: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/soft_pwm.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-armv7l-3.9/source/event_gpio.o:/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/source/event_gpio.c:60: first defined here
collect2: error: ld returned 1 exit status
error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
ERROR: Failed building wheel for RPi.GPIO
Running setup.py clean for RPi.GPIO
Failed to build RPi.GPIO
Installing collected packages: pyusb, pyserial, sysv-ipc, rpi-ws281x, RPi.GPIO, pyftdi, Adafruit-PureIO, Adafruit-PlatformDetect, adafruit-blinka
Attempting uninstall: pyusb
Found existing installation: pyusb 1.2.1
Uninstalling pyusb-1.2.1:
Successfully uninstalled pyusb-1.2.1
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Attempting uninstall: sysv-ipc
Found existing installation: sysv-ipc 1.1.0
Uninstalling sysv-ipc-1.1.0:
Successfully uninstalled sysv-ipc-1.1.0
Attempting uninstall: rpi-ws281x
Found existing installation: rpi-ws281x 4.3.1
Uninstalling rpi-ws281x-4.3.1:
Successfully uninstalled rpi-ws281x-4.3.1
Attempting uninstall: RPi.GPIO
Found existing installation: RPi.GPIO 0.7.0
Not uninstalling rpi.gpio at /usr/lib/python3/dist-packages, outside environment /usr
Can't uninstall 'RPi.GPIO'. No files were found to uninstall.
Running setup.py install for RPi.GPIO ... error
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-qt7sxjs7/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.9/RPi.GPIO
Complete output (89 lines):
running install
/usr/local/lib/python3.9/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build
running build_py
creating build
running build_ext
ERROR: Can't roll back RPi.GPIO; was not uninstalled
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/setup.py'"'"'; __file__='"'"'/tmp/pip-install-8sng21fv/rpi-gpio_d05d2ef0d9fd46089bb9337b0798ae6c/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-qt7sxjs7/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.9/RPi.GPIO Check the logs for full command output.
