i2c/SPI character LCD backpack with Speeduino
Shreyas_p
Post by Shreyas_p »
Hi!
This post is specifically to do with using an LCD display with Speeduino (an arduino based open source ECU: https://speeduino.com/home/).
The I2C library used to control LCD displays doesn't work with the speeduino as it interferes with the schedulers/interrupts in the speeduino firmware (https://speeduino.com/forum/viewtopic.php?t=3682, https://speeduino.com/forum/viewtopic.php?t=1066).
However, many say that SPI libraries work fine and the firmware itself has a sample code for an adafruit *OLED display*.
I am looking to buy the *i2c/SPI character LCD backpack* from adafruit (product ID: 292) for this reason but want to confirm that it will work with the speeduino without any hiccups.
Thanks in advance!
mikeysklar
Re: i2c/SPI character LCD backpack with Speeduino
Post by mikeysklar »
I've seen very few posts about working with speeduino in our forums. If you know your i2c will be an issue I think it is still worth trying an SPI display. You can always do a parallel LCD connection as well.
