Super Bright LE wire
- Colonel13
I want to take your LE wire and increase its intensity so that it replicates a lightning bolt for 2-4 seconds. I want to use a 110 volt power source to power the LE wire. What do you recommend.
- mikeysklar
Re: Super Bright LE wire
El Wire -
These are the more power El wire inverters we sell that are both 12vDC based. You can use them with the wall plug adapter listed on the bottom.
https://www.adafruit.com/product/448
https://www.adafruit.com/product/832
https://www.adafruit.com/product/798
If you are going to do over 3 meters of El Wire then be sure and sue the #448 inverter.
The way I've controlled El Wire for the fast flash type of effect was using a triac on the AC leads (after the inverter). You could use a transistor or relay on the DC side of the inverter, but it will not give you as much control.
- Colonel13
I purchased 3 of your inverters and they work great.
I am looking for High Brightness White Electroluminescent (EL) Wire. 2.5 to 3.5 meters in length. What product number should I order?
- mikeysklar
