Good morning everyone. I hope everyone are fine and doing well.
I am Bharath S. I am studying electronics engineering.
I am currently working in scoreboard project for my ground. I want to make bigger scoreboard. Approximately 100cm width and 50 cm height. I saw many tutorials in adafruit but every tutorial is only for smaller matrices.
In order to make large display board( 100cm width X 50cm height), what type of microcontroller we need to use? Is Adafruit Matrix portal enough to build this much larger board?
Thanks in advance.
How to make large screen by 32x32 RGB matrix
- isrobharath
- mikeysklar
Re: How to make large screen by 32x32 RGB matrix
The Matrix Portal would be a good choice.
This display is : 385mm x 190mm so a bit larger than what you had requested.
If you wanted to chain them they can get quite bit. This is our best page summarizes making large displays.
https://learn.adafruit.com/rgb-led-matr ... ple-panels
- isrobharath
Thank you so much for your valuable information sir.mikeysklar wrote:The Matrix Portal would be a good choice.
If you wanted to chain them they can get quite large. This is our best page summarizes making large displays.
