It doesn't seem like the TFT and the Feather are connected properly.
I plugged in my Feather nRF52840 Sense into the TFT using the supplied male pins, with the short ends sticking up.
However, the screen only lights up when I wiggle the Feather a certain way. I have checked that the switch for the display as a whole is on. (Video showing the display toggling off and on: https://photos.google.com/share/AF1QipM ... FGVldfN2Nn)
When I upload the example sketch when the screen is lit up (or when it's not), nothing happens.
The output from Arduino is:
Upgrading target on /dev/cu.usbmodem1101 with DFU package /private/var/folders/kp/9_gq64jj1vxgslhnjj6wmgg80000gn/T/arduino_build_288143/graphicstest_featherwing.ino.zip. Flow control is disabled, Single bank, Touch disabled
Activating new firmware
Device programmed.
174805
Lines 1918945
Horiz/Vert Lines 25390
Rectangles (outline) 22461
Rectangles (filled) 408205
Circles (filled) 352539
Circles (outline) 838868
Triangles (outline) 409180
Triangles (filled) 362303
Rounded rects (outline) 259765
Rounded rects (filled) 503906
Done!
What am I doing wrong? I'm a total newbie to Adafruit products and tinkering in general, so it's likely I didn't set something up right. Any help is much appreciated!!!
