Top half of matrix not working correctly
Sledges
Post by Sledges »
Re: Order Confirmation No: 2734105-4166970103
1 x 64x32 RGB LED Matrix - 3mm pitch[ID:2279] = $44.95
1 x Adafruit RGB Matrix Bonnet for Raspberry Pi[ID:3211] = $14.95
I purchased an LED Matrix and the top half of the matrix is not working correctly. I re-connected all components and performed multiple basic tests to try to resolve it, but nothing has worked. In test one, I try to run red text (255,0,0) and no text appears at all. In test two, I try to run white text (255,255,255) and the resultant blue text appears on the panel. Running software that is meant to display a hockey net, the pixels that should be red do not display at all, and the pixels that should be white are again blue.
I'm powering with 1 x 5V 4A (4000mA) switching power supply - UL Listed.
Could you please assist?
Run white text (255,255,255) and the resultant blue text appears
Screen Shot 2021-12-28 at 9.51.05 AM.png (638.9 KiB) Viewed 205 times
Running software that is meant to display a hockey net,  on top half the pixels that should be red do not display at all, and the pixels that should be white are again blue.
Screen Shot 2021-12-28 at 9.51.15 AM.png (859.82 KiB) Viewed 205 times
On top half, the pixels that should be red are green, and the pixels that should be white are again blue.
Screen Shot 2021-12-28 at 9.50.51 AM.png (804.08 KiB) Viewed 205 times
Sledges
Re: Top half of matrix not working correctly
Post by Sledges »
Additional photos.
Screen Shot 2021-12-28 at 10.30.52 AM.jpg (339.63 KiB) Viewed 202 times
Screen Shot 2021-12-28 at 10.30.43 AM.jpg (428.35 KiB) Viewed 202 times
Screen Shot 2021-12-28 at 10.30.34 AM.jpg (524.31 KiB) Viewed 202 times
Sledges
Post by Sledges »
Hi, I see that users who have posted issues today have received support. Can I please get a response from adafruit support as it's been over a week? Thank you.
Sledges
Post by Sledges »
No support for several weeks...Third times a charm?
adafruit_support_carter
What is the software setup on the Pi? Are you following this guide?
https://learn.adafruit.com/adafruit-rgb ... g-matrices
