Been using this eink 2.9" display for a month and a half now. Updates every 5 mins (guide said 3 mins so I rounded up to 5 for "safety".)
Started out OK but now there are horizontal lines across the display and the red seems to have bled out on the side.
Is there a way to fix this in code or is the display broken?
faulty 2.9" eink display?
- rpiloverbd
Re: faulty 2.9" eink display?
Looks like a fault has occurred. Has anyone from the Ada team contacted you regarding this matter?
- ephemerix
No - still waiting.
- ephemerix
Anyone from Adafruit with thoughts on this?
- rpiloverbd
I think you must mail them directly with you invoice number etc.
- littlebirdelectronics
@adafruit could we please have some feedback on this?
- adafruit_support_carter
Was it in constant use during the month and half? Updating every 5 minutes?Been using this eink 2.9" display for a month and a half now. Updates every 5 mins (guide said 3 mins so I rounded up to 5 for "safety".)
It was working then not working. Can you correlate that to anything?
- ephemerix
24/7 operation for a month and a half? No.adafruit_support_carter wrote:Was it in constant use during the month and half?
Your own guide says 3 minutes so not sure why 5 minutes is a problem?adafruit_support_carter wrote:Updating every 5 minutes?
https://learn.adafruit.com/adafruit-2-9 ... pectations
OK, so not 24/7 usage. But how often was the code run during the month and half?
- ephemerix
A few hours a day, max.adafruit_support_carter wrote:OK, so not 24/7 usage. But how often was the code run during the month and half?
Since when did correlation become causation? But OK, I'll play along...adafruit_support_carter wrote:It was working then not working. Can you correlate that to anything?
1. It was working
2. I followed your instructions, at settings more conservative than described
3. It's no longer working
So my take is your guide isn't even slightly conservative enough.
And while I haven't followed the instructions "exactly" I think it would be foolish to argue that if I had refreshed the display more frequently than I did this wouldn't have happened.
OK, refresh rate doesn't seem to be a probable issue.
Can you provide more info on the setup this was being used in? The photo only shows the display unattached on a breadboard. What was driving the display? How was it attached? What code was being run? How was the setup being powered? What kind of environment was the setup being used in?
- ephemerix
Using a Feather HUZZAH32. Powered via USB.
Wiring (yes it's not pretty, but that's what I had) Code:
Indoors only. It's summer here, so 20-32C depending on time of day, if the a/c is on, etc. No direct sun or anything like that, it's warm enough!
#include <Adafruit_SCD30.h>
#include "Adafruit_ThinkInk.h"
Adafruit_SCD30 scd30;
#define EPD_DC 25 // can be any pin, but required!
#define EPD_CS 26 // can be any pin, but required!
#define EPD_BUSY 21 // can set to -1 to not use a pin (will wait a fixed delay)
#define SRAM_CS 4 // can set to -1 to not use a pin (uses a lot of RAM!)
#define EPD_RESET 14 // can set to -1 and share with chip Reset (can't deep sleep)
ThinkInk_290_Tricolor_Z10 display(EPD_DC, EPD_RESET, EPD_CS, SRAM_CS, EPD_BUSY);
unsigned long previousScreenUpdateTime;
int screenUpdateFrequency = 5 * 60 * 1000; // 5 mins
float temperature;
float humidity;
float co2;
void setup(void) {
Serial.begin(115200);
while (!Serial) delay(2000);
// Try to initialize!
if (!scd30.begin()) {
Serial.println("Failed to find SCD30 chip");
while (1) {
delay(10);
Serial.println("SCD30 Found!");
// if (!scd30.setMeasurementInterval(10)){
// Serial.println("Failed to set measurement interval");
// while(1){ delay(10);}
Serial.print("Measurement Interval: ");
Serial.print(scd30.getMeasurementInterval());
Serial.println(" seconds");
display.begin(THINKINK_TRICOLOR);
previousScreenUpdateTime = millis();
delay(500);
if (scd30.dataReady()) {
Serial.println("Data available!");
if (!scd30.read()) {
Serial.println("Error reading sensor data");
return;
temperature = scd30.temperature;
humidity = scd30.relative_humidity;
co2 = scd30.CO2;
Serial.print("Temp: ");
Serial.print(temperature);
// Serial.print(" degrees C");
Serial.print(" RH: ");
Serial.print(humidity);
// Serial.print(" %");
Serial.print(" CO2: ");
Serial.print(co2, 3);
// Serial.println(" ppm");
// Serial.println("");
} else {
//Serial.println("No data");
delay(100);
if (millis() - previousScreenUpdateTime > screenUpdateFrequency) {
updateDisplay();
void updateDisplay() {
display.clearBuffer();
display.setTextSize(3);
display.setCursor(5, 5);
display.setTextColor(EPD_BLACK);
display.print("Temp: ");
if (temperature > 27) {
display.setTextColor(EPD_RED);
display.print(temperature);
display.setCursor(5, 35);
display.print("RH: ");
display.print(humidity);
display.setCursor(5, 65);
display.print("CO : ");
if (co2 > 800) {
display.print(co2);
display.setTextSize(2);
display.setCursor(41, 75);
display.print("2");
display.display();
Thanks. That all looks generally OK. The time frame here is a bit beyond are normal 30 day period:
https://www.adafruit.com/shipping
But let's go ahead and replace the display this time and see what happens.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement Eink display.
