LED Matrix 16X32 Wrong Row Ordering
uroutoftime
Post by uroutoftime »
So after setting up the LED matrix with an arduino Mega 2560 based on the following tutorial:
https://learn.adafruit.com/32x16-32x32- ... mper-wires
I found that while all of the lights are lighting up, the indexing is not correct.
To test this, I added some code to iterate through each of the 16 rows in order, but the rows lit up as follows:
Coded Row Ordering : [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15]
Actual Output Ordering:[0,4,1,5,2,6,3,7,812,9,13,10,14,11,15]
I also verified that it is not an issue with my code as I could recreate with the matrix.print() function and the default "testcolours_16x32 program.
I have verified that the connections have been set up correctly, but I was wondering if this is potentially just an issue with the LED matrix I received. This issue will NOT affect my final product as I can simply make an inbetween function to map the rows correctly, but I wanted to see if there is any known issue before going that route.
